Volkswagen Unveils Golf Gti W12-650
I love winding you lot up it so easy!!! Martin go back to sleep!! Pistonbroke you should know better & stop playing with goggle search !! I was surprised you could spell W12  ;)  Right I'm going to play with my W8 TVR !
Buzz :p
Interesting.....
(the engine is) "extremely compact in design, measuring only 513 mm in length, 715 mm in height and 710 mm in breadth"
How does that compare against an LS1 for example?  :suspect:
Will it fit in a westy then  ???  ???  :p  :p  :p  :p
:D  :D  :D  :D  :D  :D  :D
Interesting.....
sounds about the same size if a not a little smaller than my Rover V8! So yes it would! Have to make it four wheel drive though! :oops:
Interesting.....
Hmm... So hows big's the W16 from the Veyron then...
:love::devil:
Do you reckon the chassis would need srengthening...
:D
Buzz :p
Actually I was looking for the W16 that was fitted to  a  Porch Coupe
The limited edition model was  Built for export only  to USA  :sheep:
road tested by   James Dean
I wonder what became of it    ???
