XE Kent Supersports Cams
Hi, I may sell my XE Kent cams as I am going to a solid profile but please note the exhaust cam is shortened for distributor less use, ie coil pack only, I have a used set of AST1603's 278 duration and 11.04mm lift, also I have a new AST1608 inlet cam to go with them, 290 duration and 11.3mm lift. This will make them 1608's as well as  1603's. The 1608's have the same exhaust cam, just the inlet is changed, I also have 20 new hydraulic lifters from vauxhall still in there boxes. I also have a new set of Kent cams single springs, spring seats and steel caps but may have to use them on new cams, don't know yet.
I was looking for 200 quid for the cams and 100 quid for the lifters, I will keep hold of the spring kit until I have got my new cams
