1600 idle
Hi All,
My 1600 modular build car is idling too fast at 1600RPM. when i took it for the Pre SVA MOT the tested said i would fail the emissions test on this. Helpline sugested checking the voltage on the TPS.
has anyone else had this
Paul
Need more detials on wot you  have: Engine, fuel system.
- Have you rung the factory igf they supplied the ECU etc ??
is all completely from westfield. 1600 modular build supplied from WF with sigma Zetec engine and webcom alpha ECU.
Mark mentioned testing the voltage of the Throttle Position Sensor and then if it is incorrect undoing the screws and adjusting it.
have not had the chance to try this yet
Check TPS as Mark has suggested
If it's been incorrectly set you will have too high an engine idle speed
Voltage should be in the Alpha instructions...
