Looking at buying some wheels for my westy but as I need 4x108 PCD with very low offset, the only ones I can find are Peugeot fitment 4x108 ET15. Will these fit on to ford hubs, is the central bore the same on pug wheels?
Hi
They fit, however you may need to use spacers and longer bolts in order that they fill your arches at the back and miss your arches and brackets at the front.
I'm using Peugeot wheels on mine, ET15, with 195/50x15 tyres. They fit fine and spacers aren't required, the ET15 puts the rim closer to the outside of the wheel arch and further away from the cycle wing brackets.
here you go
the central bore is bigger on the pug wheels so the wheel nuts will be effectively holding it onto the car rather than being supported by the central spigot.
No worse than running budget wheels spacers IMO
nice one cheers. Its not the pug speedlines in particular but some aftermarket alloys that I have found. Whenever you say 'ford' they just give you ET38 option when you say Pug they give you ET15. (only wish I could get hold of some decent ET0!
Cheers,
A
Just put 15mm spacer onto et 15 and you have et0 :D
