Wolf in shed clothing?
John Loudon - Sponsorship Liaison
Clicky
Some sought after bits amongst it all
Like that a lot  :love:
Would love to do a track day with that everybody thinking dutton crap and destroying them all  :cool:
Feck Me... That's nearly worth buying at that price for use as a doner for a proper car!
:D
:D
Just what I was thinking.
At first I thought it was a Lotus / Caterham S4  :)
You'll have to excuse my thickness, but I'm a bit of an engine numptie.
I really would like to do something in future with either a type r or s2000 engine. If I come across a decent one I will stick it away until I'm ready to do something.
What worries me is that these engines seem quite techy and I was wondering if they will work properly without the Honda ECU / sensor stuff i.e. is the VTEC part of the engine electronic or mechanical, or is it just a straight forward engine like the rest, or can you strip it all off and put an off the shelf TB system and then have it rolling roaded / tuned?
Basically what would need to be retained from the donor to make it run correctly or is there a better way of controlling them?
Interesting point - Question really - is the V tec  cam timing change driven off oil pressure via a soleniod valve  ?(it was on my old Merc)   If so you could use Megasquirt/jolt to switch the valve above a certain Rpm  and woooosh.
Hammy's got it... The VTEC system is operated by oil pressure. At a certain RPM the ECU sends a signal to a solenoid, allowing oil to flow in a seperate gallery in the head. This fires pins across in the rocker gear, locking the followers onto a totally different cam profile.
So any ECU that can operate a switch at a pre-determined RPM *should* be fine. MHC I believe is using a DTA. I also know of a S2000 engine running Emerald.
If a Westfield has the aerodynamics of a brick......................then that must have the aerodynamics of a whole wall  :0  :0  :0  :D  :D  :p  :D
David
I think you mean some Westfiel owners have the mentallity of a p**ck. Not the aerodynamics of a brick.
Alert, Alert: Sense of humour failure  ;)  ;)
We also have damn good sense's of humour, hence the simlies under post's. We are also very good a jesting...
:D
Tell you one thing. It doesn't matter what kit you have on a day like today. They are all great fun. :D  :D  :D
