Currently fitting brake pipes. I've decided to run the front to rear down the transmission tunnel.
Question- the plate running across the bottom of the transmission tunnel I'm assumimg is the gearbox mount, further forward of that are 4 circular  bosses welded to the chassis, 2 on either side of the tunnel (approx 1/2" dia) What are these for? Don't want to run the brake pipes and then have to move them later on because I've missed something obvious :p
They can be used for anything, another gearbox plate if fitting a different gearbox but generally thet are not used
