MBE 912 ECU & Loom for XE
I am in the process of upgrading ECU on my VX car and will have available shortly an MBE 912 full injection and ignition ecu and loom. This is currently running an SBD 196 parallel throttle body kit with standard injectors and distributor.
The 912 is an Eprom based ECU with a fixed map I believe these can be changed with the right equipment but I do not have this capability, I do have two spare 912 ECUs which will be included in the sale.
The loom is professionally made and labeled. It includes connections to the standard VX temp sensor, crank position sensor and the original coil.
This has run my car without problems for the last two years.
Would be looking for about £375.00 + post for the complete kit and it will be coming available within the next 4 weeks.
Rik
May be a match to Cidersurfer's  Throbble Botties?
:t-up:  :t-up:  :t-up:
