Ady1 Posted February 21, 2007 Share Posted February 21, 2007 Hi, After a first attempt to install my Rover V8 into the chassis today I am really stuggling to keep all 3 clutch plates aligned while I bolt the whole thing to the flywheel. The only way I could think of is to use a knackered old input shaft as a dolly then bolt the clutch on to gain the compression on the plates. Has anyone got any suggestions? If not, any 1" x 23 spline input shafts going spare? Ady Quote Link to comment Share on other sites More sharing options...
congorobot Posted February 21, 2007 Share Posted February 21, 2007 QUOTE 3 clutch plates Do you mean clutch plate I have never had any problems just doing it by eye. Quote Link to comment Share on other sites More sharing options...
stu999 Posted February 21, 2007 Share Posted February 21, 2007 Not if he has a multi plate clutch... Quote Link to comment Share on other sites More sharing options...
Ady1 Posted February 21, 2007 Author Share Posted February 21, 2007 yep, it's a triple plate clutch assy. Quote Link to comment Share on other sites More sharing options...
congorobot Posted February 21, 2007 Share Posted February 21, 2007 hmmmm... sorry then, no experience of those! Have heard of people turning a bit of wood on a lathe to use as a tool. Quote Link to comment Share on other sites More sharing options...
Mark Stanton Posted February 21, 2007 Share Posted February 21, 2007 QUOTE Have heard of people turning a bit of wood on a lathe to use as a tool. mind the splinters Quote Link to comment Share on other sites More sharing options...
V 8 Posted February 21, 2007 Share Posted February 21, 2007 Ady, you'll need an old input shaft. Not only do you need to align the plates, you need to align the splines aswell. You ought to be able to get hold of one of those easily enough Quote Link to comment Share on other sites More sharing options...
Ady1 Posted February 22, 2007 Author Share Posted February 22, 2007 ..........Parts Wanted......... Cough, Cough Cheers Ady Quote Link to comment Share on other sites More sharing options...
andybennie Posted February 22, 2007 Share Posted February 22, 2007 Hi If you cant lay your hands on a shaft, a number of years ago I did as someone has already suggested, spin one out of wood on a lathe and then araldite one home wooden spline the same lenght as the three plates (you do not require all splines for alignment) making sure the spline is running in line with the wooden tool. Andy Quote Link to comment Share on other sites More sharing options...
