the linkage between my twin 45s carbs , is hitting the inlet manifold . would it ok to chop this part of the manifold out so that the linkage will sit correctly
our any other ideas
just had the car Rollin road ed today  :D  but the guy tried to change the linkage around but not enough room . he suggested cutting the manifold  away but thought id check if it would be ok first
Yep, my linkage is attached at the bottom of the carbs and when fitted fowled with the Cast web on the inlet manifold.  simple hacksaw job with buffer disc to clean up and job sorted, this had no effect on the manifold so dont worry, if you want some pictures of before and after then drop me a line.
steve
Sammy
Mine has been cut down! Works really well.
You wanna call round and have a look?
Danny
sammy, pictures sent, that's got to be worth a beer, it was b@@dy freezing in th garage.
