MBE 967iD ECU, loom, TPS
I now have available a MBE 967iD ECU, with wiring loom, and TPS.
Removed because I am finally upgrading to throttle bodies, this is possibly the best way to get sparks for your VX. Converts the VX engine to wasted spark ignition. You will need to supply a wasted spark coil - available from SBD etc, or down at the local scrappy. Can be sourced from Peugeots 106's etc...
All of the items for sale was originally sourced from SBD.
The loom was specified with the optional comms lead, allowing the user to alter timing and rev limit settings if required.
It is also specced with throttle position sensor wiring, and the TPS is included (with bracketry to fit to Weber carb).
Posted to your door for £250 :t-up:
