Major Stare Posted January 20, 2007 Posted January 20, 2007 Carbon Airfilter Backplate, made by MHC/Mick, which means its possibly the best Will not fit my MegaSquirt conversion Pilot holes drilled to accept Pipercross Sausage airfilter, no holes in actual back plate, just needs finishing off. £65.00 inc P&P As you can see, it wont fit my car
Chasmon Posted January 22, 2007 Posted January 22, 2007 Out of interest is the extra cable for idle adjustment? If so whats on the other end just ascrew adjustment in cabin? Cheers
mhc Posted January 22, 2007 Posted January 22, 2007 IF any one is interested. There are a few more sitting on the shelf ,undrilled. Same price, regards.
mhc Posted January 22, 2007 Posted January 22, 2007 I have just looked in my messager inbox. It seems that there are more than a few carbon tarts out there. Please be patient and I will get to you all in turn. The filter backplates will need a final trim around the outside edge to remove the flash line from the mould. Its a little bit of work to compensate for the low price of a proper prepreg carbon product. Regards.
Major Stare Posted January 22, 2007 Author Posted January 22, 2007 Out of interest is the extra cable for idle adjustment? If so whats on the other end just ascrew adjustment in cabin? Cheers The extra cable is for the throttle, i have ran 2x throttle cables (incase one snaps)
jak Posted January 22, 2007 Posted January 22, 2007 The extra cable is for the throttle, i have ran 2x throttle cables (incase one snaps) Do they snap then?
