Jenvy fuel rail with -6 connectors
As the title says, does anyone have a jenvey fuel rail with -6 end fittings for a twin throttle body set up.
I found out from Jenvey that you cant swap the end fittings, so i have 2 fuel rails with push on tails if anyone wants to swap.
cheers,
steve
what's -6 mean ?, Im puttting TB's together and will be looking for a fuel rail with scrw on fittings, is that what I need ?
Sorry to jump in, but at least it keeps your thread up top.  :D
exactly. The"-6" bit refers to the size of the screw fitting. So you have to spec the screw in end fittings to the rail when you buy it.
Push on ones are fine, but i seem to be taking my throttle bodies off too many times :bangshead:
Why not get some weld on dash fittings from Think Automotive and get them welded on. Thats what I did with the Ali fuel rail on my Busa Turbo Plenum.
Bazzer
good idea, how much did it cost to get the ali welding done?
anyone got any suggestions for ali welders in the south prepared to do a 10min job
I dont think my welding ability is good enough to be 100% fuel tight :p
Bazzer
Weld on adaptors cost about £3 each from think and the TIG welding cost me a drink to a mate.
Hope that helps
Bazzer
cheers Bazzer, another job on the long list!
