gee_fin Posted December 17, 2006 Posted December 17, 2006 Complete set of Jenvey twin 45mm throttle bodies. Taken from mildy tuned XE engine. For sale complete with - - fuel rail - grey injectors - XE inlet manifold - pre-preg carbon-fibre trumpets - throttle pot - throttle linkage - section of braided hose with finishers - full detail sheets Not putting them on eBay until after Christmas so available here beforehand!. All in excellent working order, ready to bolt on. Throttle body information available from - www.jenvey.co.uk/ For sale at £500 the lot (entire kit in photos). I also have available a complete Omex 600 ECU to run these if desired (not included in price). The Omex is complete with wiring loom (previously used on XE, but loom is complete - it hasn't been pruned of it's turbo/ancillary sections) with water sensor, choice of crank sensor (Omex or Ford type), trigger wheel (three sizes choices including external crank trigger wheel and mount if desired). Complete with manuals/documentation, software and PC cable. Currently loaded with map for mildy tuned XE, have all the base/startup maps available if required. Taken from a running 200+bhp Vauxhall XE, lovely responsive setup. Omex ECU essentially seems to be a GEMS ECU so very powerful, hell, can even run your anti-lag if you so desire. Copied blurb - QUOTE Semi-sequential fuel injection for up to 4 cylinder engines Grouped injection for up to 8 cylinders Distributorless ignition for up to 4 cylinders Distributor ignition for up to 8 cylinders Programmable load and speed sites TPS or MAP can be used for main load sensing Wide range of crank trigger patterns are suitable (user programmable) Turbo wastegate control Turbo anti-lag system Variable cam control Traction control (Software upgrade coming soon) Narrow and wide band lambda support Push/pull, and single line idle controls in addition to scattered spark control Knock sensing capability 3 programmable outputs switched on user controlled inputs (eg boost, coolant temp etc) Security protected calibrations Full throttle gearchange Intercooler water spray control Water injection control Nitrous ignition retard and fuel enrichment Two cooling fan controls Barometric compensation with external sensor Uses the latest version of the superb MAP2000 Windows programming software Suitable for normally aspirated or boosted engines Inbuilt independent fuel and ignition rev limiters Separate Tachometer, Shift Light and Fuel Pump outputs Magnetic or Hall Effect crank and cam sensors Automatic interpolation between mapped sites Sophisticated acceleration fuelling setup Various harness options from economical semi-assembled to full race quality bespoke looms Battery voltage compensation table for fuel injectors (not just a simple number) Battery compensation and engine speed compensation for coil charge time Mappable coolant temperature compensation for engine warm-up Air & coolant temperature compensation for fuel injection pulse width Separate cold cranking and decay tables in addition to warm-up fuelling User settable ignition trim based on air temperature, coolant temperature, and barometric pressure Separate start advance for cranking provides easy starting for high compression engines Deceleration fuel cut-off feature for road engines Maximum recommended engine speed 12,750 RPM AND LOADS MORE Information on Omex 600 ECU available from - www.omextechnology.co.uk/Ecus/600/omem600.htm These kits are £1500+vat not taking into account the pre-preg carbon trumpets and trigger wheel/sensor options. For sale in excellent condition - Omex 600 entire kit (loom, trigger wheels/sensors etc) + throttle bodies available at £900 the lot. Everything you need to throttle body/3D map your machine over the winter break. Mild cams and Kent vernier pulleys also available if desired, along with superlight flywheel and Tilton 7.5" twin plate clutch... just need to get the engine out this week for photos... Contactable on 07747 60 60 66, graeme@fluke-motorsport.co.uk, located in Northampton, doesn't included delivery but drop me a line and I may be passing.
gee_fin Posted December 17, 2006 Author Posted December 17, 2006 Oof, that didn't last long. Throttle bodies provisionally sold Always makes you wonder if you should've asked for more! Anyhows, complete Omex 600 ECU with loom, sensors, trigger wheel(s), manual, software etc still available. Will be looking for £450. Photos and seperate ad to follow... Cheers! Graeme.
salexander Posted December 17, 2006 Posted December 17, 2006 Graeme, emailed you re clutch. What torque capacity. type of plates, condition, price etc. Ta
