Raceline Wet Sump Oil Strainer
Hi Guys
Does the oil straner in a Raceline wet sump require any attention??? I will be doing an oil change today and wondered whether or not i needed to do anything.
John
Hi John - I assume you are talking about the filter fitted in the front of the sump on a zetec engine?  If so, the answer is yes.  Just remove it and clean out any debris you find.  It's quite interesting to have a look at what you find...!  If you don’t clean it, you could potentially reduce the flow through the pump and into the engine, which you wouldn’t want to do.....be careful when replacing that everything is seated correctly…
