I'm trying to carryout a clean install of SBS 2003 onto a dell Poweredge 830 server.
Was all going well but when it reboots after copying all the files and starts teh server setup wizard it says no network device found and proceeds no further.
If I go into control panel both the onboard adaptor and additional NIC are working and enabled.
Any ideas. Perhaps they are not compatible but seems a bit unlikely.
I have used what I think are the latest drivers.
David
Hi David,
Just a shot in the dark. Does it require \ Do you have a network lead plugged into said Network port?
I think Isa Server needs to be plugged into a hub before it can be installed, SBS may be the same!
:D   :D  :D  :D
Edited to say Isa-server also requires 2 network adapters
ah good idea.
I was installing standalone but will try connecting to a hub.
Yup, its been over a year since I installed an SBS2003 box but Im pretty sure it needs an active NIC connection to continue.
