scoobydevil Posted October 22, 2006 Posted October 22, 2006 did a search and can't find this as a topic so started a new one sorry if it has been covered. just wondered who has tried it and what results you had had. i have tried it in my mx6 which is 2.6 v6 iand have found my fuel economy has fallen greatly however the perfomance is superb. going back to the fuel economy under hard driving you can watch the fuel gauge drop much more then with normal unleaded. as a foot note i am having the car serviced at ABP and will report if it makes any differance. Quote
mjones31 Posted October 22, 2006 Posted October 22, 2006 Scoobydevil Just read your post,Been thinking of trying this shell v-max but cant picture a shell garage near me.Noticed your in walsall.Where,s your nearest as im only in wednesbury !!! Soon as i find some i,ll let you know what i think. Mark Quote
ljsanders Posted October 22, 2006 Posted October 22, 2006 Do a search for Optimax, BP Ultimate or Tesco 99 and expect similar results. Not much point in filling your Westy with it unless its been specifically mapped for it or has a knock sensor. If you have a zetec, these don't have knock sensors so good as throwing money down the drain. But, my remapped Leon Cupra, which I can adjust the timing via a gadget to suit the fuel I put in it, really loves the stuff! Lee Quote
Guest Posted October 22, 2006 Posted October 22, 2006 shame we get weak v-power here and not the proper stuff the rest of europe get .......... Quote
scruffythefirst Posted October 22, 2006 Posted October 22, 2006 I only put v-power, ultimate or tesco 99 in the dax. bl**** cossie engines, costs a fortune Quote
a4drk Posted October 22, 2006 Posted October 22, 2006 What about the bike engined cars then? I run my Megablade on Optimax (well used to ) Quote
Mick S Posted October 22, 2006 Posted October 22, 2006 Had mixed results running a tweaked V8 in my Westie on Shells V-power. Filled up at a small village garage and paid £1.06 per litre and the car did seem to go like hell, it also ran much smoother through towns. I have tried it at a number of motorway services with only slight improvements so not sure if all garages are selling the same goods. I travel about 10,000 miles in my company car through Europe every year and notice that their fuels (especially in Germany) make a big improvement in performance and economy for both Diesel and petrol engines. I’m sure we are using poorer quality fuels in this country. We also have a V8 Discovery running on Duel fuel (Petrol and Autogas) this runs much better on gas for both performance and fuel economy than the Shell V-power. Autogas is about 102 octane and less than half the price of V power. Quote
slippy Posted October 22, 2006 Posted October 22, 2006 What about the bike engined cars then? I run my Megablade on Optimax (well used to ) We run it in our Blade and it seems to like it, does the engine have to be mapped to run on it Quote
ljsanders Posted October 22, 2006 Posted October 22, 2006 If your car has a knock sensor to retard/adjust the timing to reduce pinking, then it will benefit more by putting higher rated RON fuel in it. If it doesn't and your car hasn't been mapped to use the higher rated RON, about the only benefit you will have is that the additional cleaning additives will help. In my 1800 Speedsport, I notice virtually no difference whatsoever over regular 95 RON. However, if I find myself out of fuel and at a Tesco's, I won't put the 95 RON in it because thats the crappest 95 RON fuel on the market (in terms of cleaning additives for your engine), so I put in the decent 99 RON stuff. Quote
robthehungrymonkey Posted October 23, 2006 Posted October 23, 2006 I'd be interested in knowing the non-performance benefits to using a "Premium" fuel. Is it worth doing every few tanks worth? Or do you need to run it for a while for it to make any difference? Quote
cast iron Posted October 23, 2006 Posted October 23, 2006 Be carefull when reffering to knock sensors, they only work up to about 3K then background noise makes them redundant so in road cars they are only used for slow speed problems you know pulling away with a caravan in 4th gear dont expect them to protect your motor screaming at 7K if the timing is out Optimax and BP ultimate both improve economy and drivebility on my 350Z but then the book says thats whats supposed to be in it so I'm only cheating by filling up with regular stuff. Quote
Ian Podmore Posted October 23, 2006 Posted October 23, 2006 All V Power in this country is 'brewed' at the Shell Stanlow refinery, so should be all the same. I have noticed that the fumes that come off Optimax / V Power are much stronger than normal unleaded, so I don't suppose it stays 'fresh' for very long. Quote
Morbius Posted October 23, 2006 Posted October 23, 2006 I have to use SuperUnleaded in my tin-top ('new' shape Golf 1.6FSI) . V Power seems better than Optimax was (98RON vs 97?) and BP Ultimate is OK, as is the Texaco one. The fuel economy is worse than my old 1.6 Golf, whatever I use , but the car seems quicker than the old one . I think the new emissions gubbins is taking more power from the engine . I get marginally better fuel economy with SuperUnleaded in the Westy, but not enough to merit the higher cost. This cooler weather is better for top-end power, though, because my air temperature sensor does not give a reliable reading, so I disabled the temperature correction in the ECU. Quote
pistonbroke Posted October 23, 2006 Posted October 23, 2006 It knocked about £5 off of my 0 - 100 time Quote
