Chris Elworthy Posted October 22, 2006 Posted October 22, 2006 FOR SALE: NOW SOLD Weber Alpha P1150 ECU with Loom, Air temp Sensor and Crank Sensor. All you need to fit this will be a suiable trigger disc for your engine and a throttle position switch for your carbs. The loom is complete with RS232 interface. It has been mapped for my Nat Asp YB running on Twin 45s. I first fitted this system in 2002 and it started first click with the base map, it has never missed a beat since. I am now fitting injection hence this unit is for sale. The fitting instructions are present and complete. I am reliably informed that the access codes are only available to approved dealers such as Northampton Motorsport for example. They made an excellent job of setting mine up and checking it every now and again. £100 o.n.o. PM me if you need any further info. Chris
Chris Elworthy Posted October 22, 2006 Author Posted October 22, 2006 SOLD. Thanks for all of your interest. Chris
