Fuel filter with 12mm ends
Hi, I need a pre-pump fuel filter with 12mm ends but the only ones I kind find are the expensive alloy £50 ones for fuel injection (I will be using one of these after the pump).  I don't want to start getting messy with joiners and reducers.
I'm looking for something like:-
Think Auto
Made me one of the above with custom ends.
around 30 quid with the vat if I remember correct
Can I ask why you need a pre AND post pump filter? I don't think the pump is likely to cause much contamination so can you not just put the £50 jobbis before the pump?  ???  :t-up:
OEM installations use a course filter before the pump and a fine filter after the pump...
Although there is a lot of discussion. Westfield fit as standard a post pump injection filter these are cheap replaceable units. The tanks on recent cars have a finger filter to remove debris that may damage the pump...
So, seeing as I bought my tank about a month ago, it's likely to have a filter in it and hence no need for a pre-pump filter?
I've had a fuel pump let go before now and it's not pretty - you should have seen the rubbish that I had to flush from the fuel lines (before the filter) after that happened.  If there was no post pump filter, I might have been looking at a complete fuel rail, injector and regulator replacement.
Local motor factors, less than a quid
Nope, the're all 8mm ends.
You can always have a chat with W/F about this. I was advised by them that my setup is fine.
Tank=>pump=>filter=>fuel rail=>regulator=>tank return
HTH
