Chris.B Posted September 10, 2006 Share Posted September 10, 2006 SOLD Tim Duncan / Just the One style Aeroscreen. Drilled for fitting. £25 + p&p or collect from Bath. Hi-res 2.5Mb pics here and here and here. Link to comment Share on other sites More sharing options...
michaelcoombs Posted September 10, 2006 Share Posted September 10, 2006 narrow or wide? or does it fit both? Link to comment Share on other sites More sharing options...
Chris.B Posted September 10, 2006 Author Share Posted September 10, 2006 narrow or wide? or does it fit both? It was fitted to my SeiW - don't know if it fit a narrow. Will look into it. Link to comment Share on other sites More sharing options...
Chris.B Posted September 10, 2006 Author Share Posted September 10, 2006 narrow or wide? or does it fit both? Yes it will fit both. Look at this site here and click on Products / Aeroscreens and you'll see pictures of one fitted to pre-lits and narrow Westfields. Link to comment Share on other sites More sharing options...
Chris.B Posted September 11, 2006 Author Share Posted September 11, 2006 Correction I originally said drilled for mirrors - that's a mistake & the original post is corrected It's just drilled for fitting. You'll see from the pics there's a 5mm hole in each corner (to hold down to the scuttle) and two 5mm slots in the moulded flange under the screen also to hold to the scuttle. All of these are needed to mount it. Link to comment Share on other sites More sharing options...
Chris.B Posted September 14, 2006 Author Share Posted September 14, 2006 SOLD Link to comment Share on other sites More sharing options...
