Speedo drive
Have a pre-lit with x-flow and RS2000 gearbox and speedo cables last about 500 miles.
Can anyone advise where I can get a right-angled drive adapter from ? I've done a brief search and had a scan round the internet without much luck.
Many thanks in advance !
Westfield!
Quite expensive but a nice bit of kit - I think mine was in region of £70
edited to add - but that was fro a type 9, don't know if they're different
Don't mean to hijack the thread, but it seems a bit stupid to start a "speedo drive" thread above abother one...
Is there a way to replace a faulty speedo drive unit without removing the gearbox? My speedo is knackered and I've been told that this is the cause and solution.
Another speedo problem :D
Mine gets up to 100 and then starts going backwards?
I think theres a right nagle drive on Ebay - found it under a search for Caterham
My speedo at the moment reads correctly when i'm coasting and reads half the speed when i'm on the loud pedal ??? (electonic speedo rather than mechanical)
Langy - that sounds like a  sensor postioning problem - under load is the rortating bit moving away from the sensor slightly, so you only pick up a signal some of the time ? Checking the sensor position and/or  diff/gearbox (as appropiate) mount might be fruitful
Cheers Hammy, it has been on my 'list of things to do' all summer
