Bananaman Posted September 5, 2006 Posted September 5, 2006 Hi I had a puncture on the trailer at the weekend and now need a 140/70R12 trailer tyre, just thought someone might have an spare that is not needed any longer kicking about in the garage. 5 Stud Brian james 12" wheel......... Quote
John Loudon - Sponsorship Liaison Posted September 5, 2006 Posted September 5, 2006 Cant you just get a tyre from somewhere or do you need the rim as well? John PM - sent Quote
Bananaman Posted September 5, 2006 Author Posted September 5, 2006 Cant you just get a tyre from somewhere or do you need the rim as well? John PM - sent This size of tyre has been discontinued and as such i would need 2 replacements as the replacement reccomended by BJ is a 145/80R12 and i would need 2 as you need the same tyre on each axel..... Just thought somebody might have one lying around in there garage... Quote
John Loudon - Sponsorship Liaison Posted September 5, 2006 Posted September 5, 2006 Does it need to be 8 ply? If not, try a caravan breaker or someone who sells Mini stuff. Some minis are 12" and also some caravans. John Edited to add - you dont specifically need a 5 stud wheel the. A 4 stud would be OK as long as it has the tyre that you need and can be swapped over Quote
Bananaman Posted September 5, 2006 Author Posted September 5, 2006 Needs to be 6 ply......... Apparentley the A-max uses a 140/70R12 but only 4 ply.... Quote
R Tyas Posted September 5, 2006 Posted September 5, 2006 Hi fela, had a puncher on one of my trailer tyres this weekend i got mine repaired £10.00 bargin Quote
Bananaman Posted September 5, 2006 Author Posted September 5, 2006 Hi Rob think it's a bit beyond repair, it's got a gash in it about 10" long............. How you doing?? I'm off to Cadwell on Thursday evening and then a week on Sat for a sprint (got myself a set of slicks to play with.. Be good to see you if your around Andy Quote
Mark Stanton Posted September 5, 2006 Posted September 5, 2006 Try here for trailer spares Trailer Bits Quote
