Hi Guys,
Help please. I have been recommended to both of the above list 1b tyre as a wet but which is the better. The Avon is the most expensive by some way. So if the Avon is better in the wet is it worth the extra cost. Or is there a better wet tyre.
Many thanks
Dave
Think they'll be much of a muchness. if you can get them in a simmilar aspect to your dry tyres then this would be good as the susspenting setting will not get upset...... :t-up:
No idea Im affraid....  :(
But to hi-jact your thread slightly, If you sprinting guys had only the choice of either 13inch A048's in soft compound or 15inch A539's, which would you choose to run?  ???
I have a feeling next sundays event is going to be my first wet event...  :bangshead:  :bangshead:
