can anyone tell me what the correct tracking setting should be for a 1992 seiw. I know the components are from an escort but does this mean it is set up the same?
I run mine dead parallel
Some run a little toe in
Some run a little toe out
If you want to improve the set up remove the bump steer in compresion, or at least get it to be a small amount of toe out in bump
