conibear Posted August 13, 2006 Posted August 13, 2006 The Avon slicks I am using presently are 8.2X20X13 on the front and 9.2X22X13 on the rear in A56/A53 compound. The car is a 2003 SEIW with widetrack at the front. Currently, my camber settings are, front @ 1.5deg negative and the rear @ 0.7deg negative. Does this seem about right ta Ian Quote
Guest Posted August 13, 2006 Posted August 13, 2006 if anything a little to much on the front .............. however , tyre temp gauge,tyre pressure gauge and a stopwatch/datalogger are the only true ways to tell ............................ you've not got the hang of this testing lark have you Quote
Blatman Posted August 13, 2006 Posted August 13, 2006 If they're crossplies, then I agree with Harv, too much camber... Quote
V 8 Posted August 13, 2006 Posted August 13, 2006 Don't agree, 1.5 deg is ok, even on xplies. It's about what I run on mine. Quote
conibear Posted August 13, 2006 Author Posted August 13, 2006 Cheers all, I adjusted the front camber during my last meeting and car was improved on the front end there's no doubt about that. It's approx. 1.5deg neg. Seems as though I am not far out then Harvey, I don't get much time to test TBH, with the summer weather and being an A/C contractor Quote
conibear Posted August 13, 2006 Author Posted August 13, 2006 Although the basics in suspension geometry are important, I'm starting to believe the rule book should be ignored Quote
Blatman Posted August 13, 2006 Posted August 13, 2006 Don't agree, 1.5 deg is ok, even on xplies. It's about what I run on mine. And just how close is yours to a "normal" wide track Westfield? What works for yours may not necessarilly work for Westfields with a more "traditional" front suspension set up Quote
V 8 Posted August 14, 2006 Posted August 14, 2006 Although the basics in suspension geometry are important, I'm starting to believe the rule book should be ignored Yes, I'm coming rapidly to that conclusion Quote
Guest Posted August 14, 2006 Posted August 14, 2006 throw away the rull books and work with the temp gun and preasure gauge , get about a 2psi increase in pressure and an even temp spread and you'll be getting close. Quote
V 8 Posted August 14, 2006 Posted August 14, 2006 Now that's good advice me old m8. temp guns about £30 from maplins Quote
Guest Posted August 14, 2006 Posted August 14, 2006 yep , because all the advice in the world will never tell you whats happening on any day on any circuit .......... the gun will , the art is understanding what you see. Quote
conibear Posted August 14, 2006 Author Posted August 14, 2006 But with my infrared gun I can get an even temperature across the tyre with any (within reason) camber setting, simply by adjusting the respective tyre pressure. Am I right in stating, that getting the camber setting right would generate more heat into the tyre, than if it wasn't set right. Thus improving tyre adhesion. If this is right, then getting an even temperature across the tyre will not tell me if my camber is set to the optimum angle. Quote
