Thinking of doing some track days.
Apart from a helmet, can anyone let me know what else i will need so that i can go on a track. I suspect most tracks will have their own set of items required,but are there any compulsory items needed at all tracks.
1 litre catch tank
Crash Helmet
Car
and most importantly are the following
courtesy for fellow drivers
some common sense
the ability to ensure to read all instructions given by the trackday organisers
and finally good hearing for the on the day drivers briefing  ;)  ;)
Have fun and enjoy  :D
QUOTE
1 litre catch tank
Is this to stop oil spills?
Or am I missing something. Is this compulsery for all trackdays. :durr:
Car
Doh! Wouldn't have thought of that one - Pretty obvious though unless you were going to run around the track :D
Catch tank it to catch any oil being thrown out of the cam cover, they breath faily heavy when pushed around a track, and then there's the G-Force.
Put it this way, would you like to enter a corner full belt and find somebody had dropped some oil on the track ...?
Compulsory = Yes!
Tigger
1 litre catch tank
It certainly is to stop oil spills. Most, if not all TDO's ask for a catch tank to be fitted - if the engine 'breathes' to atmosphere... :t-up:
Cheers for that. I've got a catch tank fitted so thats a bit of luck. :D
I think it is there so the pressure in the engine and gearbox doesn't get to much and in effect allows it to breathe. Is this right?
That was a quick reply by you two :D . I've asked a question you have already answered before i got my reply in  :p
Take spare cans of fuel! I think all say that you need at least a long sleve tshirt, have to cover up your arms. Worth taking spanners, few tools, cable ties, gaffa tape etc. poss a spare wheel?  :D
1 litre catch tank
Done plenty of trackdays with all the top companies - none specify a catch tank but you would need it for scruteneering at race events.
by fitting one - it can save a lot of embarassment and hold-ups if you do drop oil  ;)  ;)
Most of the "companies" don't note it as mandatory - quite simply it does'nt matter to them how much time is lost by having to clean up an oil spillage, it's not their track-time thats lost, the money is still in the bank  :D  ;) consider it courtesy to your fellow track day drivers  ;)
1 litre catch tank
Well, even if they don't, IMHO a person that goes to a trackday (or indeed, even uses the car on the road) without one is a fool...   :suspect:
If they can get to the spillage before it causes a crash... :(
Simple things as well that you overlook, bottles or drink (as usually v expensive there!) poss a few fold away chairs? Spare oil to top up with just in case! Tyre pump with a good guage ( v important!)
Tie wraps! Invaluable.
I also take a basic tool kit, a rag to wipe oil, tyre pump with gauge, all fluids (oil, brake fluid, and water) and overalls and latex gloves in case I have to get stuck in.
The day before I check the torque on all of the suspension and wheel bolts (I found one loose before Abingdon recently) and brake fluid, oil and coolant levels. Also check all the brake shoes and pads.
Track day organisers don't really require much. Usually just that you meet the relevant noise limits, have a driver's licence, and that your car is road legal.
QUOTE
That's some trackday  :D  :D  :devil:  :devil:  :blush:  :D
Recommendations for a nice catch tank for a i4 Duratech under construction? Money not a desperate consideration.
Best spot to fit then in engine bay??
Sorry about all the ???'s
edited to say didn't realise 3? would give a  ???  smiley from the quick post box. I'll have to remember that. Oh and learn the code for the others :durr:
