ADR Uprights, Centre lock wheels, brakes.
Looking to create the ultimate Westfield? These parts will save at least 5kgs per corner and mean you can change wheels in a jiffy!
Complete set of everything you need for the 4 corners of your car! All brand new and never used.
ADR Engineering aluminium uprights with axles, bearings, hubs, brake bells, brake disks, wheel nuts (centrelock), drive flanges.
Set of 5 (one as a spare) Image Split Rims in 13*6.5 to suite the centre lock fixing. Image have the drawings/CAD model to make others in different sizes (eg 15inch), and the wheels shown can easily be made wider with different rim halves.
Set of 4 Wilwood Dynalite calipers, and caliper brackets to suite these uprights.
These parts are the dogs danglies. The uprights are as used on the ADR Sport 2 and new Sport 3 race-cars. They are very strong, light and very flexible to use as they take a bolt on upper bracket that you can either fabricate or machine.
LM25 cast aluminium uprights, with SKF bearings, hardened steel drive pins, billet machined and gold anodised drive flanges, and brake bells. Wilwood rotors. Anodised wheel retaining caps and 8 wheel nuts. Top hat spacers for lower balljoints. High tensile bolts for lower balljoint and bolts & k-nuts for upper steering arms.
Billet gold anodised aluminium brackets for wilwood dynalite calipers. Note centre-lock wheels are SVA compliant. You could if you'd prefer modify these to suit 4 bolt wheels.
CAD models available.
Please note that these parts cost over £4000 new!
£1500  :suspect:  :down:
Drop me an e-mail if interested!
This topic is now closed to further replies.
