HI EVERYONE,
                     JUST WONDERED IF ANYONE MAY HAVE A WIRING DIAGRAM FOR A EARLY WEST FIELD WITH ONLY TWO FUSES. I BOUGHT THE CAR IN NEED OF FINISHING AND REFUSE TO BE BEATEN LIKE THE PREVIOUS OWNERS. THE PROBLEM IS THE WIRING LOOM IS FINE BUT I SEEM TO BE STRUGELING WITH FINDING THE IGNITION CIRCUITS. ANY HELP PICTURES WOULD BE GREATELY APPRECIATED AS I HAVE LOTS OF WIRES AROUND THE FUSE BOX AND NO IDEA WERE THEY ALL GO. MANY THANKS FURRY ???
What's with the CAPS?  Do you know what year westfield it is?  Do you mean only 2 fuses or 2 fuse boxes?  I'm a complete noob unfortunately but answers to those questions might help others help you.
put sum photos up and we may help you of the car wireing thats all nothing else please for now may be l can help just by looking at them for you see what you can do furry :p
I have a 2 fuse 1989 se main harness diagram in front of me right now :)
and a scanner that refuses to play ball :(
Graham :bangshead:
I have an original westfield drawing for the old wiring loom (March 89) it looks like a 5 year old drew it.  I can email larger photos if required.  My loom has gone in the bin already so I can't check anything, any help will be from memory or the drawing.
General wiring colours
Black - B
Brown - N
Purple - P
Green - G
White - W
Red - R
Yellow - Y
Grey - S ( slate )
Light green - LG
Blue - U
Brown - 12V feed from battery (Via starter solenoid) for alternator, fuse box feed, lights and ignition switch feed
Purple - fused Permanent 12V for horn & hazards
Green - fused swiched ( ignition on ) 12V for powering most circuits
Red - side lights and gauge illumination
Blue - lights   (blue & white - main beam and warning light) (blue & red - dip beam)
Black  - Earths
Rear harness connection
White - 12V ( can be used for electric fuel pump )
Green/red - l/h indicator
Green/white - r/h indicator
Red - side lights
Green - 12V feed for fuel sender, hand brake and reverse switches.
Red/blue - fog light
Black/white - Hand brake switch (brake fluid warning light test)
Green/black - fuel gauge return
Green/purple - brake lights
Thanks everyone, hopefully will be able to get it runnin g now. i will keep you posted. :D
