steering wheel extension
gumstabber
I've got long legs and short arms. The result being that my hands catch on my knees as I steer. If I can bring the wheel towards me about 1.5inch then all should be fine and dandy. Any ideas.
Also - at some point in the not too distant future I also wanted to fit a removable wheel, so any spacer thing I get it would be good if it will attach to both a standard and removable wheel boss.
Thanks in advance
Link to comment
Found a local machine shop who made me this for £20:
Took them a piece of paper with all the dimensions on and they made it to measure.  :D  :t-up:
Link to comment
That steering will be a b******* to use when you put the seats back in.....That's a daft winter mod if ever I saw one :D
Link to comment
You should see where I put the gear stick  :p  :p
Link to comment
Why not kill 2 birds with one stone!
To fit a removable steering wheel, you will need to get the steering column modified. Take your column into Westfield (or post) and then will fit the detachable boss to the column whilst extending to suit.
All you then need to do is buy a new steering wheel. Suggest you go for a flat bottomed wheel (like me) to give extra leg room.
Link to comment
