10X Posted July 11, 2006 Posted July 11, 2006 Greeting from Kansas. This is my first post on your forum. I desperately need some images of a Phase 2 Zetec motor mounted in a Sport 1800. I have everything to mount a Phase 1 engine but they were not used in the US and not available here. I would like some close up shots of the motor mounts in particular. Thanks Harry Quote
Blatman Posted July 12, 2006 Posted July 12, 2006 Welcome Phase 2 is an unfamiliar term to describe a Zetec here in the UK. What year was the engine made? It'll give us a chance to better work out which type of Zetec you are describing. Quote
10X Posted July 12, 2006 Author Posted July 12, 2006 Thanks Blatman, I have 2 engines one is out of a 2001 Focus and the other a 2000 Escort. Both are 2.0L I have been told I need a silver top to fit all of the parts I presently have. We call these engines ZX2 and ZX1. Would you please explain what the different color tops mean. Thanks Harry Quote
Blatman Posted July 12, 2006 Posted July 12, 2006 I'm not a big Zetec expert, BUT the silver tops are the older type Zeteces, with Black Tops being introduced fairly recently. The vast majority of Zetecs in the UK will be silver tops. Go to the links page at www.wscc.co.uk, and check out the web sites of Steve Richards, and David East. Both have built top quality Zetec engined cars with excellent build diaries... Quote
kevip6 Posted July 12, 2006 Posted July 12, 2006 Hello, I fitted a 2ltr Focus Black Top Zetec to a new SEIW build recently. check out Module 3 on my build site www.westfieldbuild.net and see if that gives you any info. I believe the engine mounts are the same as for the earlier Zetec engines but the one near the water pump needs a slight modification to the top left corner. HTH Quote
