james grayley Posted July 10, 2006 Posted July 10, 2006 Quick question for the plumbers... Need to change a kitchen sink, don't have a stop dangler.... Well there may be a stop dangler but it must be back in the street and serving several flats on one main, some of the owners of which i don't get on with..... Anyway, sink taps are soldered on to copper pipes, can i freeze both hot and cold, cut and fit new compression fittings / braided connections for new taps? Can i get the freezing spray from B & Q or do i need a plumbers merchant? Cheers. Quote
Gromit Posted July 10, 2006 Posted July 10, 2006 Try these. , and when the pipes are frozen, cut the pipes and bung a couple of these on the ends (their push fit so no need for spanners or tape/sealer. Quote
nlash Posted July 10, 2006 Posted July 10, 2006 Screwfix Edit... Spooky, same result on google search then Quote
Gromit Posted July 10, 2006 Posted July 10, 2006 Edit... Spooky, same result on google search then Nope, just most of our gear from Screwfix anyway. Quote
Thrustyjust Posted July 10, 2006 Posted July 10, 2006 just phone the water board.They will locate your outside tap in the street etc.If it's knacked they will fit a new one.My mums was 20 feet under the front garden!!!! They had to dig it up and put it at hands reach.You can then put one in the house for safety sake.You 'MUST' have your own stopcock,not shared with others. Quote
MVS Posted July 10, 2006 Posted July 10, 2006 Little tip; Use a roller type cutter (pipeslice if you can run to one) NOT hacksaw as any minute rough edge, even after smoothing, will damage the O-ring in any push fit fittings. They will seal initially and lull you into a false sense of security, then start to leak months or years later. Seen loads do it, regardless of quality/care smoothing. Quote
ACW Posted July 10, 2006 Posted July 10, 2006 I would def locate your stop dangler now before you have a leak. Quote
