Peter M Posted July 4, 2006 Posted July 4, 2006 Looking on advice and tips on how to fit a westfield boot cover. Quote
slippy Posted July 4, 2006 Posted July 4, 2006 Hi Peter do you mean just a cover and not a boot box ? if so give me a buzz 079200 28206 as we have done three up to now or try I think it's steppen wolfs site Quote
slippy Posted July 4, 2006 Posted July 4, 2006 Here you go mate Click on tips, Installing a RAC roll bar, then about half way down the page Quote
Peter M Posted July 4, 2006 Author Posted July 4, 2006 Slippy thanks but this is what i was needing advice on. clicky Quote
slippy Posted July 4, 2006 Posted July 4, 2006 Aggh a Tonneau, is it the spacing of the rivets ? Quote
Peter M Posted July 4, 2006 Author Posted July 4, 2006 Yes and any other advice,what to be careful about. Quote
slippy Posted July 4, 2006 Posted July 4, 2006 I 'think' the tonneau comes pre riveted so the spacings are standard as far as I know the build manual/or the factory should tell what distance the rivets need to be I have been wrong in the past though just ask Balters aka Blatman Quote
Peter M Posted July 4, 2006 Author Posted July 4, 2006 Nothing fitted to tonneau just a bag of popper fixings for cover and tub. Quote
nikpro Posted July 4, 2006 Posted July 4, 2006 Peter, first off you need to fix the bases of the popers to the body - use the dimensions in the build manual for this - they are the same location as if you were fitting a hood (obviously you won't be because of the areo screen. Lay the cover over the boot area so its fit is snug around roll bar seat belt mounts etc. mark the rear corners of the toneau where the bases are then fit two popers on each corner making sure the cover is taught along the back. Fix the very front poper on each side ensuring a good even tension. mark the locations of the rest of the popers on the toneau and fit. Quote
Peter M Posted July 5, 2006 Author Posted July 5, 2006 Cheers guys.I think this is the worst part of the build for me. Quote
Morbius Posted July 5, 2006 Posted July 5, 2006 Peter, first off you need to fix the bases of the popers to the body - use the dimensions in the build manual for this - they are the same location as if you were fitting a hood (obviously you won't be because of the areo screen. Lay the cover over the boot area so its fit is snug around roll bar seat belt mounts etc. mark the rear corners of the toneau where the bases are then fit two popers on each corner making sure the cover is taught along the back. Fix the very front poper on each side ensuring a good even tension. mark the locations of the rest of the popers on the toneau and fit. I agree with all of this except that once you have fitted the popper bases to the body per the positions described in the manuel, you need to start at the middle popper on the back and work out to both sides to get the tension right. Before drilling the holes that you have marked on the masking tape on the body, lay out the cover and see whether the popper bases are hidden under the cover when placed in the marked position. You might find that the positions of the popper bases on the body seem a bit low. Don't worry provided that the raised 'top hat' part of the base is no more than 5mm outside the stitching, as you need to stretch the cover when you fit it to make it look neat. This same principle applies if you are fitting a hood, as I have done (although I have only driven the car once with it up - the hood that is ). Quote
