gadrego Posted June 27, 2006 Posted June 27, 2006 Open to offers on anything you don't like the price of! Narrow body hood and sidescreens, Black, Hood has new front fasteners. Drivers sidescreen's pull strap is missing but otherwise all in good nick. Reduced to £65 + p&p Narrow body half doors, black, passenger side has no studs in and has obviously never been used. Driver's side has full compliment of studs. SOLD Narrow body windscreen, + trim panel + mirrors + stanchions + crash pad. Ali frame and stanchions, needs a polish and has remnants of sealing on inside of stanchions. Trim panel is Oxford navy. Windscreen uncracked. I'd prefer this to be picked up, don't fancy posting the screen for obvious reasons. Reduced to £50 Wiper motor + bracket from a narrow body sold Brand new, still in box Red top 20 Battery from Demon Tweeks. I've not even opened this since its arrived. Only weighs 4.9kg and has no problem powering an XE on TB's. Cost £90 delivered from DT. sold VDO oil press sender M14 thread to suit XE or K series (or use an adaptor for other engines) SOLD VDO Water temp sender (think its tapped M10 or M12) came off XE thermostat. £3 + p&p 4l Mobil Motorsport 15w50 Engine oil. Ideal for a VX to avoid tappy noises! Sold Type 9 clutch cable to suit top mount pedals. Brand new and unused sold Throttle Cable to suit twin carbs and top mount pedals. Brand new. sold 2x Willains 3 point harnesses in Blue. No idea of age I'm afraid. Reduced to £15 + p&p Pair of Wipers and arms in black. Barely used. sold Timing strut. Quite neat and just requires a couple of rivnuts on the nose cone to fit. Sold Toggle switches. Think there's a full set here. Faded a little so would need polishing up. Come with connectors and a couple of warning lights. Sold Standard Steering Wheel and crash pad. Needs a clean sold Set of VDO guages. Speedo (showing 11012 miles), 0-7k rev counter, oil press guage, fuel guage and water temp guage. All of the bevels needs a lick of paint. Speedo comes with cable drive to suit type 9. sold Edited to add: SBD MBE mapping lead with USB Converter and driver CD Sold New Items Header tank and brand new bracket. Tank needs a clean. £5 + p&p Rollbar camera Clamp. Manfroto Superclamp. Cost £35 new, used twice, sold Items all in Whitley Bay near Newcastle if you'd prefer to collect.
Chasmon Posted June 27, 2006 Posted June 27, 2006 2nd Dibs on the wiper motor. Tempted on the switches as well, will they clean up OK? Are the pins on the back suitbale for Westfield Loom? Cheers Charlie
oioi Posted June 27, 2006 Posted June 27, 2006 b*******, just thrown a wiper motor, wipers, windscreen etc in the bin!
gadrego Posted June 27, 2006 Author Posted June 27, 2006 2nd Dibs on the wiper motor. Tempted on the switches as well, will they clean up OK? Are the pins on the back suitbale for Westfield Loom? Cheers Charlie I'll keep you posted on Wiper motor. Switches should clean up fine. A search will reveal what strange concoction cleans them up best. Switches come with plugs which to the best of my knowledge are standard Westfield.
gadrego Posted June 27, 2006 Author Posted June 27, 2006 b*******, just thrown a wiper motor, wipers, windscreen etc in the bin! Fool! You can buy mine to replace them if you want!
Buzz Billsberry Posted June 28, 2006 Posted June 28, 2006 Timing strut. VDO oil press sender M14 thread to suit XE or K series (or use an adaptor for other engines) £5 + p&p Narrow body half doors, Iill take the above please Where r u based? Regards Buzz
Chasmon Posted June 28, 2006 Posted June 28, 2006 I'll take the switches then please. I'll PM you this evening.
gadrego Posted June 28, 2006 Author Posted June 28, 2006 If I've not replied to any PM's, send me another as I've been struggling to keep up!
westie321 Posted June 28, 2006 Posted June 28, 2006 Could I have 1st dibbs re Red Top battery please. Would be interested to know size, W,H,L Andy Can PM my details later
