Hopefully going for visit to Kingswinford shortly and am going to order my SEi starter kit, Been thinking about it now for a while and have tried to compile a list of whats required (apart from large credit card, Internet access, Hotline to factory, Hotline to Blatman, some knowledge always helps and a huge sense of humour ! )
If anyone can come up with what I've missed I'd be very grateful as I feel a bit of preperation always helps.
Parts Required for Westfield
(outwith that supplied in Sei starter kit)
Engine VX 2.0 Redtop or Similar.
Gearbox Ford Type 9
Diff XR4x4 LSD
Wheels and tyres.
Bellhousing VX to Type9
Clutch kit and cable
Release Bearing and Fork
Sump for engine
Throttle Bodies and ECU System
Front Uprights
Front Hubs
Front Wheel Bearings
Front Brake Calipers
Front Brake Discs
Track Rod Ends
Bottom Ball Joints
Top Ball Joints
Steering Rack
Steering Rack Mounts
Lower Steering Column
Engine Mounting Rubbers
Shock Absorber Kit inc Springs
Radiator
Radiator Mounts
Coolant Hoses
Coolant Expansion Tank
Cooling Fan
Exhaust System
Exhaust Manifold
Alternator
Propshaft
Battery and Tray
Horn
Aeroscreen or Windscreen (and associated parts).
Dash Assembly
Instruments
Steering Wheel
Gearshift Lever
Handbrake Lever
Carpets
Seats
Seat Mountings
Harnesses
Wiring Loom
Mirrors
Fuel Tank
HP Fuel Pump
LP Fuel Pump
Swirl Pot
Rear Hubs
Handbrake Cable
Rear Brake Calipers
Rear Brake Discs
Rear Wheel Bearings
Rear driveshafts and CV joints
All Lighting
And a partridge in a pear tree !  :xmas:
Thanks everyone for any help.
Edited to update list.
QUOTE
Hotline to Blatman
Try 08457 90 90 90
:0
If this becomes a relatively complete list, then I can see it being useful as an FAQ. Any objections to me moving it there? ???
Andy
Not yet. Lets let it develop on a forum that actually get's read...
You old cynic you...
Good point though. Let's see how it develops.
Andy
QUOTE
Fuel Tank
HP Fuel Pump
LP Fuel Pump
Swirl Pot
Why not just get a baffled tank and a HP fuel pump? No need for the swirl pot and LP pump then.
John
This is the list I typed up from my SEiGHT starter kit:
Please look further past this list, as I have include what else I have to purchase (so far!):
Scuttle Wide Body ZK004   1125000   1
GRP Nose ducting Ali Rad 1131625 1
Ducting intake Allum Rad M115/6 1132125 1
Nose - Wide body ducted ZK008 1134000 1
Bonnet - Wide V8 0 ZK006 1206000 1
Wing cycle for 205 Tyres - M185R 1255000 2
Wing Rear O/S ZK017 1261000 1
Wing Rear N/S ZK016 1262000 1
Body Wide detachable - ZK001 1302000 1
Boot Box Wide body - ZK012 1350000 1
Fillet - W/Screen wide body - ZK011 13906XX 1
GRP safety belt cover 1392125 1
Chassis SEiGHT RHD EPX 1440014 1
Panel set-SEIW 1800 in/pendant 1420112 1
Handbrake cable w'field sierra 2322002 1
Hose-brake SEi Rear 2311007 2
Hose-brake front 2311014 2
M10 X 1 Female 3 way brass tee 2313006 2
Clip handbrake cable retention 2329003 1
Pedal box back pl MK4 SEiW/V8 4921112 1
Pedal box lid 4921113 1
Spacer Fuse Box 1417960 4
25 Dia circlip external 3219006 4
Differential MTG spacer 3224043 1
Trunnion - accelerator cable 4922007 1
M5 X 8 CUP PT SKT Grub screw 8174085 1
Rod End Male "/" UNF 4316118 4
Westfield Badge 50 S/A BLK/SIL 6131007 1
Westfield Badge 25 S/A BLK/SIL 4319001 4
Hub - Rear B Type C/W studs 4321013 2
Drive Shaft MK2 LH 3213036 1
Drive Shaft MK2 RH 3213037 1
Upright rear assembly RH 4330003 1
Upright rear assembly LH 4330004 1
Cable accelerator (Mini) 4922004 1
Bush - differential MTG (fitted) 4313064 4
Stud-diff MTG wide plated 7212015 1
Stud M12 X 300 BZP diff MTG 7212300 1
Spacer wing bracket damper pl 1417028 2
Bearing rod end reducing sleeve 4319001 4
RHD Pivot pedal box V8 4920017 1
Hose-brake with banjo M/Cylind 2311011 1
Steering column ASM+Lock EPX 5222014 1
Suspension Bush 4313001 19
Brake Pipe kit - Rover Serp 2310062 1
Cycle wing brkt ALI UPRMK3 LH EPX 5585072 1
Cycle wing brkt ALI UPRMK3 RH EPX 5585073 1
Wishbone-rear top wide +25 EPX 4311152 2
Wishbone-RRBTM wide +25 W/O EPX 4312172 2
Eng MTG BRKT V8 RH MK2 EPX BLK 1722147 1
Engine MTG BRKT EPX V8 LH MK2 1722148 1
Bracket-Headlamp LH EPX 3514042 1
Bracket-Headlamp RH EPX 3514043 1
Diff stable BRKT MK2 EPX WO BU 3224031 1
Wishbone-FRT BTM EPX WO Bush 3711052 2
Wishbone-FRT TOP W/O BUSH EPX 3712052 2
Spare wheel carrier EPX 5525008 1
Chassis plate 900Kg 6132006 1
Fastner Kit - SEI Wide body basic : 7300116 1
1/2" UNF Lock nut 7132008 4
7/16" x 4" UNF hex head bolt (8.8) 7811167 2
7/16" x 3.3/4" UNF hex head bolt 7811157 2
7/16" x 3" hex head bolt 7811127 4
7/16" x 2.1/2" hex head bolt 7811107 21
7/16" UNF nyloc nut 7133007 29
7/16" T & Chamf washer 6823TU7 72
7/16" repair washer 6853AU7 8
M12 x 1.75 P type nyloc nut 7123012 4
M12 T & Chamf washer 6823TY2 8
M10 x 25 x 1.5 hex head set screw (10.9) 8123250 2
M10 single lock washer 6811010 6
M8 x 60 Hex head bolt 8111608 1
M8 x 50 Hex head bolt 8111508 1
M8 x 35 Hex head bolt 8111358 4
M8 x 25 Hex head set screw 8121258 4
M8 x 20 Hes head set screw 8121208 4
M8 x 1.25 P.type nyloc nut 7123008 14
M8 Washer T & Chamf 6802801 14
M8 spring washer 6811008 4
M6 x 1.0 P.type nyloc nut 7123006 2
M6 T & chamf washer 6823UP6 2
M5 x 0.8 x 25 Butt head skt screw 8132255 4
M5 x 0.8 Nyloc P type P & P nut 7123005 4
M5 T & chamf washer 6823TJ5 4
M5 x 10 Pan Head (Taptite) setscrew 6611510 45
Pop rivet - Dome sealed 9.5 x 4 dia. 6511011 500
Ford Scorpio 3.36 LSD differential (new)     1
Ford Spec Diff oil - BC304C Q1197783 3
Bolts for upper diff stud to chassis (M12x65mm)  2
Silicon sealant gasket (ford OEM) Q1217470 1
Filler Plug - magnetic (ford OEM) Q6118746 1
Replacement TORX bolt (ford OEM) Q1625498 1
Oil breather tube (ford OEM) Q6725174 1
Install metalastic bush into diff stablisation brk   1
Extra wheel studs (set of 8 for rear hubs) SS37 1
Thread lock (loctite 243) for 24 allen bolts   4
Westfield Upright Assembly - pair 3700142 1
Fuel pipe 1830mm Zei 4022001 3
Tie wrap clip 6311014 20
Lead battery positive - V8 293008 1
Aluminium front hubs - pair (Compbrake) CMB0301 1
Front Wheel bearing Kit - pair QHQWB115C 1
Rover V8 (High Torque) Starter motor   1
Hose - 8m bore Fuel 0871026 4
M10 thick cooper washers 6802010 10
Handbrake lever gaitor for SEIW 2323001 1
Handbrake lever sealing PAD 2323007 1
Wiring loom-rover v8-EFi-Serp   2921017   1
Convoluted cable protection 7mm LMA259 2
Convoluted cable protection 12mm LMA265 2
Convoluted cable protection 24mm LMA266 2
Carriage charge   1
Convoluted cable protection split 7mm LMA259/ST 1
Convoluted cable protection split 12mm LMA265/ST 3
Convoluted cable protection 10mm   4
Inertia fuel switch
How about a RAC roll bar and 4 point harnesses
They're not things you need, although I would tend to agree that it's a good idea to fit them.
Andy
OMG ! Thats a comprehensive list ! Cheers mate.
and still growing, it does not include the engine, ancilliaries, gearbox, propshaft, intrumentation or seats, etc.
I forgot to add a gap between the starter list and my list.
The item:
is the start of my list.
Have a look at this list Reidy, there may be something you have forgotten!!
Body
Chassis/Body (inc Powdercoating, Detachable Arches)
Nose Cone Grill
Roll bar (RAC)
Slicone Sealant
Body fitting kit (inc Locks & Bung Kit)
Engine bay
Alternator
Carburettors or Throttle Bodies
Clutch plate
Clutch release bearing
Cooling Fan
Cooling system hoses
ECU if using T.Body's
Engine
Shallow sump
Bellhousing
Exhaust Manifold And Silencer
Exhaust Mounting
Rad fitting kit
Suspension
Front Ball Joints (Top & Bottom)
Front Hubs
Shock Absorber kit Std (Inc springs)
Front Uprights
Brakes
Front Disks
Handbrake Gaitor & Fixing kit
Handbrake Lever And Cable
Handbrake Switch
Rear Brake Discs
Rear Calipers
Brake Pads
Interior
Carpet set
Interior mirror
Dash
Gear Knob
Seat Belts (or Harnesses)
Seat (Padded Race)
Seat Mounts
Electrical
Battery
Battery Tray
Horn
Instrument Set
Light set
Switch Set
Wiring Loom
Battery Leads
Switches set (with warning lights)
Drivetrain
Differential LSD
Rear hub nuts (R/h & L/H) with washers
CV Joints
Gearbox mount (Type 9)
Gearbox (Type 9)
Outer Drive Shafts
Propshaft (Type 9 to Sierra Diff)
Fuel System
Fuel Cap
Fuel Pipe 8mm (5 mtr)
Fuel Pump (Injection)
Fuel Regulator
Fuel Tank With Sender
Rigid Fuel Pipes
Fuel Filter
Fuel Pipe fittings
Cooling System
Hose Kit
Header tank
Radiator (Alloy 2 row)
Steering
Steering Column (Lower)
Steering Rack (Quickrack)
Steering Wheel
Steering Wheel Boss
Track Rod Ends
Wheels
Wheels/Nuts/Spacers
Tyres
Screen
Windscreen (inc Mirrors)
Washer bottle
Wiper motor and wipers
Other
SVA Kit
Options
Kick strips
Crash pad
Widetrack
Anti Roll bar (Front & back)
Hood
Sidescreens
Tonneau
Powdercoated alloy panels
Exterior side panels
Lowered floor
Tigger
Doh, Adam beat me to it but my list is less specific and more general if you know what I mean
(Must type faster)
Tigger
