timandchris Posted June 17, 2006 Posted June 17, 2006 We have never 'bled' anything before (what a pair of total numpties).... Think now is the time to fill the clutch reservoir even though haven't got bodywork on yet. 1. Presumably bog standard hydraulic fluid? 2. Presumably fill up the reservoir, open the nipple under gearbox pump clutch until fluid comes through close nipple? Thanks in advance for your help. Quote
Jack T Posted June 17, 2006 Posted June 17, 2006 Just use normal hydraulic fluid same as your brakes. When i did mine i opened the bleed nipple pumped the pedal, closed the nipple and released the pedal, over and over until all the air was gone. I seem to remember it twas pretty easy. Good luck Jack Quote
