Westfield SEiW - 1996 - 1600cc Vauxhall
1996 Westfield SEiW – built from a kit by me between May and August 1996.
The engine is from a Vauxhall Corsa GSi (1.6 16v) producing around 185bhp and was completely stripped and rebuilt before it was fitted to the car in 2002.
The car has covered a little over 23,000 miles from new and the new engine, etc. a little over 7,000.  I have every invoice for every part on the car (plus a few old ones besides) and copious amounts of paperwork – instructions, registration correspondence, etc.
Detailed spec is as follows:
Steering :
• Cat Motorsport quick rack – 2.2 ratio, reduced to 1.9 with lock stops
• EN3B steering column with no steering lock / ignition barrel
• Racetech quick release boss / suede steering wheel
Suspension – Front :
• AVO adjustable dampers (steel) with spherical bearings
• 9” springs – 275lbs
• Cortina cast iron uprights (powder coated)
• Cat Motorsport aluminium hubs
• Poly bushed lower wishbones – standard track
• Rose-jointed upper wishbones – standard track
• (these allow fine tuning of camber and castor angles)
Suspension – Rear :
• 10” springs – 180lbs
• Poly bushed upper and lower wishbones
• Westfield cast aluminium uprights
• Westfield modified Ford Sierra driveshafts
Brakes – Front :
• Fluke Motorsport lightweight discs
• Outlaw M-16 4 pot aluminium calipers
• Hawk HP Plus brake pads
• Aeroquip steel braided brake lines
Brakes – Rear :
• Sierra 4x4 calipers
• Red Stuff brake pads
Brakes – General :
• AP large bore master cylinder (13/16” bore)
• Aeroquip steel braided hose throughout the car – no solid pipes
• Wilwood brake bias valve
Engine :
• 1600cc 16 valve Vauxhall Ecotec engine (from early Vauxhall Corsa Gsi – it had completed approximately 38,000 miles before it was completely rebuilt by myself and my father in 2002)
• Bottom end completely balanced by Gosnays – crank, flywheel, clutch, pulleys, rods, pistons, etc.
• Standard crank (main and rod journals planished prior to assembly) – safe to 9,5000rpm per SBD
• Arrow steel con rods
• Omega forged “high top” pistons (block bored / honed by Gosnays to 79.05mm specifically for new pistons)
• Lightened and balanced standard flywheel
• Helix uprated clutch cover
• Helix sprung paddle clutch
• Cable clutch release mechanism
• Inlet camshaft – 11mm Lift 278 degrees duration
• Exhaust camshaft – 11.4mm Lift 284 degrees duration
• Vernier cam pullies
• Standard valves (individually hand lapped and sealed)
• Uprated valve springs (head machined for valve spring and cam clearance – no further work would be required to fit wilder cams)
• Titanium valve caps
• Uprated hydraulic cam followers (retained for ease of maintenance compared to solid cam followers and shimming) – safe to 8,300rpm per SBD
• Uprated steel cambelt pullies
• New water pump
• New bearings, fasteners, seals and gaskets throughout
• Rolling road mapped by Pro-Tune in Barnet and consistently seen to produce 150bhp plus at the rear wheels (approximately 180-185bhp at the flywheel) on super-unleaded petrol
Oil system :
• SBD / Pace dry sump system – sealed type so engine breathers have been removed / sealed
• “Slim Jim” oil pump
• Low profile cast aluminium sump pan with dual scavenges (filtered)
• Crank pulley dowel-pinned to crank to prevent slippage
• Risbriger “Cool-tec” aerospace spec oil filter
• Motec 19 row oil cooler
• SBD dry sump tank
• Motec aluminium oil catch tank
• Aeroquip FC322 hose used throughout (with heat shielding in places)
• Aeroquip / Speedflow -10 and -12 push-on type aluminium fittings used throughout
Fuel system :
• Westfield fuel injection type tank – powder coated black
• Pre-pump filter (push on fittings)
• High pressure fuel pump
• Pre injector fuel filter (-6 fittings)
• Jenvey fuel rail
• 45mm Jenvey individual throttle bodies
• Jenvey intake manifold (matched to throttle bodies and head)
• Bosch “cream” injectors  (uprated Siemens injectors have been purchased but not yet fitted / mapped)
• Billet aluminium fuel pressure regulator
• Aeroquip / Speedflow -6 push-on type aluminium fittings used throughout
• ITG foam air filter
• MBE 967 ECU and custom loom, running wide-band, closed-loop lambda control and barometric pressure sensor.
Exhaust :
• SBD 4-2-1 exhaust manifold
• Camcoated inside and out
• SBD 6” diameter carbon silencer
• End fittings camcoated inside and out
Gearbox :
• Tran-X (Ford Type 9) straight cut, close ratio synchromesh gear set
• 2.48 1st gear
• 1.69 2nd gear
• 1.27 3rd gear
• 1.00 4th gear
• 0.87 5th gear – helical to reduce noise
• Flowtech aluminium gearbox casing and lid (with drain plug)
• Westfield gear-lever extension
• Billet aluminium quick-shift gear lever
• Redline MTL gearbox oil
Diff :
• Standard Sierra 4x4 viscous limited slip diff - ratio 3.92.  CWP swapped by Road and Race Transmissions
• K&N breather filter fitted
• Redline Heavy Shockproof diff oil
Cooling system :
• VW Golf double pass aluminium / plastic radiator
• 85 degree fan switch (I think !)
• Electric fan
• Pace custom aluminium header tank
• 74 degree thermostat
Dashboard / Interior :
• Aim MXL dash logger system, loom and Aim sensors
• Battery master cut-out switch
• Push button start
• LED indicator / warning lights throughout
• Indicator self-canceling timer unit
Miscellaneous :
• Navy blue bodywork – standard Westfield factory colour
• Caged full roll cage in T45 tubing – custom made for the car and fitted by Caged
• Boot box fitted
• Tonneau cover
• Hawker SB30 gel battery
• Aeroscreen
• Caterham style front indicator pods
• 4”  headlights
• Fog / reversing lights
• Spare wheel carrier (not fitted)
• Flush-fitting aluminium fuel filler
• All alloy panels have been painted to prevent corrosion
• All wishbones, etc. re-powder-coated in early 2002
• All suspension ball-joints and rose-joints replaced 2002
• Willans 6 point driver harness with 3” shoulder straps and pull-down lap straps and twist-release buckle
• Willans 4 point passenger with 2” straps and pull-down lap straps with push-button buckle
• 13” x 5.5” Alleycat alloy wheels, fitted with Yokohama A048R tyres (M compound)
Spares :
• Standard Ford Type 9 gearbox
• Cortina brake discs – solid (front)
• Escort brake discs – solid (rear)
• Springs - various
• Suspension bushes – various, both poly and nylon - unused
• Dashboard – carbon fibre
• Wheel bearings - front
• Alternator – Nippon Denso type
• Clutch release bearing
• Driver’s seat and mounting brackets
• Carbon fibre silencer tube
• Diffuser – carbon / foam / GRP - unfitted
More pics can be found here:
http://www.westfield-world.com/Pics_nick2.html
I built the car as a real 'arrive and drive' car you could use on the road and for trackdays.  It doesn't have mentally hard suspension, it's not got rose-jointed suspension all round, it has sensible gearing, etc.   What it does have is lots of bits to make it light, yet reliable, and easy to maintain.  It's a nice car to drive slowly and 'enthusiastically' !!
Price is £10,995 ono.
Best suggestion, given how busy I am with work at the moment, would be to drop me an e-mail or PM via this site and I'll get back to you with my mobile number as soon as I can.
Thanks for looking
Nick
Now you put it up for sale ................. wish you'd have done it 2 years ago  :D  :D  :D
Good Luck Nick  :D  ;)
Cheers.
I should be at Curborough later this month if anyone fancies a look at the car.
It really is a lovely car...
...and if you can't afford his, you could always buy mine! ;):D
Class E winning car in the right hands...
Nick
Do you want to sell any of the spares separately? As I have same Engine / Car am interested. Give me a call on my mobile 07711 795887.
Concur above comments this is a great car.
Simon.
  • 2 weeks later...
Back to the top again.
  • 1 month later...
Back to the top, seeing as no b******* seems even vaguely interested :(
Might be time to look at breaking it up and selling it in bits, except I can't be done with the hassle....
  • 1 year later...
A promise kept.
I picked this car up on Saturday and *thrashed* it around Bruntingthorpe. A couple of minor issues to be rectified but other than that it is a top car and a testament to the skills of both Nick and Ian.
Again, many thanks to Nick and Ian for delivering it, hope to see you guys around in 2008 (and I'll try not to use the helpline for idiot questions too much).
Nice Car Peter,
I think from memory I considered buying this about two years ago, then I stumbled accross the duck mobile.
good luck with it mate  :t-up:
Jocksport
Top car  ;)  :D - do me a favour Pete - sod off onto slicks please  :D  :D  :p  :p  :p  :devil:  :devil:  :D  :D  :D
Yes, didn't you just !!
20 litres of fuel added BEFORE lunchtime (on top of the tankful it arrived with !! ) was testament to that !!  You certainly seemed to be enjoying it and keeping up with bigger engined cars.
Look after it, and make sure you clean up in the Speed Series next year ;)
oh. no pressure then :D  :D  :D
Let's hope the driver matches the car. Beyond that, who knows.
Ahh, Asterix, you've got Nicks car which BTW is featured on my site.
Do I take it you want the name on the page changed to yourself?
Nicks Old Car
Tigger
