Flywheel,Clutch,Bell Housing and Gearbox Install
Hi Guys
I will be hopefully fitting my Engine this weekend and i am after some advice or ideally instructions on bolting the transmission side all together. I will be using the following components -
2.0 Duratec
Raceline Flywheel
AP Clutch and Pressure Plate
Raceline Bellhousing and Actuator
Type 9 Gearbox
The engine is dated as being 2006 so i was unable to pick up a Haynes Manual or anything like. Any help or suggestions appreciated.
John
