How to attach number plate into nosecone cleanly
I know this is real noddy - but for number plate fitting into the nosecone (below the grille) are fixings supplied when the numberplate is made - and do they generally have something to screw or bolt into on the inside of the nosecone - or should I just be looking to use some m5 nuts and bolts to attach it? Or is there a nut/bolt free method that can withstand 130+ mph...?
If you go into most car accessory shops they sell triangular shaped number plate brackets, these can be fixed onto the lower part of the nose with nuts & bolts, then the number plate can be stuck to it.
It's steady as a rock, but if it does catch on anything the brackets will bend & the plate moves out of the way causing no damage to the nosecone or numberplate.
How fast  :suspect:
Hang it from a hinge - it moves out of the way when struck and hangs nice and legally when stationary. Might blow back a bit at speed though - still there's always some snag isn't there? ???
(not my idea officer, received wisdom) :D
How fast  :suspect:
must be a bec  ;)
Well the car is listed as max speed 130mph and I travel to the 'ring a fair few times a year - so figure it might max out there. Previous cars have topped that speed - but they have been more aerodynamic than the Westie.
I drilled through the underside of the nosecone at an appropriate width for the plate, then made a couple of bits of ali that mount on the internal side of the base of the nosecone (M5 bolts), bend up over the bottom lip of the nose and hang down the front.  I then mounted the plate onto those (Plastic no plate bolts).  You can mount it as high or low as you want and I know that it copes with 110 ish from the sprint at Croft.
Rivnuts in the nose cone and plastic number plate bolts.
Tie wraps....  ???
:D:D:p
For SVA simply use loads of double sided outdoor sticky pads, then remove the licence plate forever more....
Not been pulled over (touch wood) just yet for not having a registration plate on the front.
This doesn't even cause a problem at MOT.
Your local happy shopper (Wilko Motorsave) stock stick on plates. You have to sign to say it's not going on a car, but who's gonna check?
Queue barrage of comments against my point of view...
Apart from it's not a problem for sva as you don't have a plate then.... :p  :D  :D
I got a smaller than legal sized plate for my first MOT a couple of weeks ago, just dropped it into the gap between grill and nosecone. Passed MOT and now it's back in the boot box where it belongs. Ready for next year (or if I get stopped) :D
ive never had one bin stoped once loading the ferry on my way home from the ring dont bother it fell of officer :D
