Tokesalot was at my house ealier and upon leaving, the electrics on his pug 206 deisel decided to have a fit
:0
now it was no urgent concern until he turned off the ignition , and the central locking and (sounded like)every other relay on the car was doing a Roy Castle record breaking tap dancing attempt  ???
then the burning smells filled the car  :down:  so very calmly he pulled the bonnett catch and pulled the lever on the quick release battery +ve connection ........result.......
after a short while we commented on how lucky that with a quick flick the battery could be disconnected to prevent the possible damage from fire etc  which got me thinking  ???  ???
I've never seen a quick release battery disconnector ever, do some models have them as std ,none of my cars ever had one
not into conspiracy theories but do some cars need devices like this to stop burnouts   :0
Ever thought it could have been a dodgy battery connection that caused the fault in the first place ?
that would have been my first suspect  :t-up:
No ,never thought of that, but he knows a man who knows a man , who may be able to sort it
Are quick releases factory pug fit  ???
Our AO has something on his battery. He twists it a couple of times and it disconnects one side of the battery, like a poor-man's cut off switch.
Andy
ive got 2 on my westie. really just for that peace of mind that i can whip them off quick if i ever need to.
ive had excavators catch fire before,and you wouldnt believe how something as easy as disconnecting the battery becomes the longest job imaginable.
pure peace of mind for less than a tenner.id say its gotta be worth it.
darren :D
darren :D
If its of concern then maybe think to use a battery isolator switch.
Fitted "outside" the engine bay , no need to open the lid and "feed the fire" with a nice supply  fresh oxygen .
can switch off and isolate "immediatly" , at the first hint of trouble
A simple isolator switch cost a few small £'s   and is a doddle to fit
Race  spec one is a few  more quid and a little more complex .
