Mark B Posted April 27, 2006 Posted April 27, 2006 I understand what you're saying Blatters & it's plausable, but in practise the lower spring rate does work fine, my car along with all other speedsports is fitted with 200LB 2.25ID front springs + 160LB 2.25ID rears and it works spot on imo. If you have arbs you can run slightly softer springs aswell as having the shocks on a softer setting, this helps with grip especially for road use (over bumps etc) & means the arb is doing the job of controlling body roll rather than the shock & spring, it also seems to give a better ride quality. I am considering changing my front springs though as since I moved over to GTS widetrack the wishbone mounting point is moved out approx 10mm so 250 - 275LBs might be in order..... Quote
Blatman Posted April 27, 2006 Posted April 27, 2006 Niot saying they don't work fine, it's just that *IMHO* they're a bit soft and that perhaps something a little stiffer may work better. The Zetec is not so light that it's a million miles away from Vx weight, and most Vx's run stiffer than 220lb springs, even with ARB's. In the battle for handling balance, pitch is (should be) a concern, as should roll. But as I say, this is just my opinion, based on the numbers we are discussing. Everyone else will have a different opinion, and will no doubt jump all over me... again... Quote
combatsapph Posted April 27, 2006 Author Posted April 27, 2006 Okay, just bought some springs 280 front and 170 rear (I'm 105kg ) - think that should do fine - thanks for all your help guys Quote
Mark B Posted April 27, 2006 Posted April 27, 2006 Everyone else will have a different opinion, and will no doubt jump all over me... again... Quote
