Anyone know the part number, for a 2.0 Zetec. I understand that the Mondeo one is to big. The previous owner said it was a Cooper Z107, Halfors only has Champion and own brand. Ive done a search with no luck.
Ocean
If it's the same as the 1800 zetec filter I got from Halfrauds, which was a shorter one to prevent it rubbing against the steering column, then I'll check tonight and post it up. :)
Mat.
I don't have a champion part no but see if they can cross reference these-
Mahle OC 11 or FRAM PH2830
Otherwise just ask for a filter to fit a 1.4 Renault Fuego 1980 - 1984. ( bought one last night funnily enough).
Cheers,
Mark.
The short Oil Filter suitable for a 1800 zetec is Halfords Part  No. HOF264
Mat. :)
My 1800 Zetec came with a filter which I traced by part number as a Ford 1600 Zetec unit. If this is any help. Fits OK.
I fitted a HOF266 to my 2.0 Zetec, think it's from a Renault 5.
HTH  :t-up:
Mel
I fitted a Champion C104 to my zetec about 2 weeks ago.
The C104 was the one I used on my 98 SEW so naturally that's what I purchased for the 91 SEiW when I upgraded that to a 1800 Zetec. However it was 10mm too long and fouled the steering rack so I ended up using the HOF264 as mentioned by Mat.  IIRC this a Focus 1.4 Zetec filter.
Risks with Mixed Threads
Some time ago I tested Halfords filters for suitability and bought a Renault one. I fitted it to the zetec engine in my car and also onto a spare oil pump assembly I had. On the one the filter would screw on and grip, apparently normally, and on the other it gave stripped thread symtoms when tightened. On closer investigation with a vernier caliper I found that the Renault thread was M20 and the Zetec one was 3/4 inch (19,05 mm)  on the pump. The threads must have a similar pitch and with the 1mm difference the thread grooves overlap, but with reduced engagement. Obviously some people have got away with it but there could be a failure under pressure.
Kinell....seems t'me any oil filter will fit.Av we been duped all these years I ask meself.In the beginning there wos only one oil filter and there still is with different numbers  :p
  • 3 months later...
have fitted a Z87 which is off a renault, are you running throttle bodies because I trying to fit the orginal plastic manifold and the steering shaft wont fit there must be a extra uj and support in just wondered what you had
Unipart GFE210 on my 2.0 Zetec at 4.86 + vat.
Apparently Renault changed the thread on the filters from 3/4" to 20 mm in 1984. So it seems as though if you are looking for a R5 filter you should make sure it is for a Pre 1984 model, not later.
I bought a R5 Champion one from Halfords which was C108 - however bottled it and bought one from factory which was WIX WL7064 marked as 3x4 x 16 unf.
