Painting brake disc edges
Adam,look out for the postie in the morning :)
I guess the engine might reach a few hundred degrees
The manifold will certainly see high temps, I guess I could apply a small patch of hammerite to one of the pipes under the bonnet to see how it bears up.
I suspect Hammerite will melt and maybe even burn at manifold temperatures. If you are thinking of painting the manifold then only High temperature paint will do (IMO :) ).
The engine is water cooled so the outside of the block should not reach temperatures higher than 100C ;) .
I still believe that for the cost (similar to hammerite) engine paint is a worth while investment. Surface temperatures on the block may exceed the levels elsewhere due to the heat radiated form the manifold.
HTH
I wasn't going to paint any more than a test stroke - just interested to know how hot it can go!
Cheers, Justin, will do.
