Painting brake disc edges
I was wondering around Halfords today and brake caliper paint caught my eye. I was intending on getting some for my calipers (when I get them) but as was going to use the same paint to paint the rear disc centres and edges. All the caliper paint was bright vivid colours of course and I wanted black. So in wandered into the engine paint section. I sought the highest temperature black was described as V.H.T. (hand brushing type), the specification says upto 650C.
Now I have got home I have the destructions and they say to cure the paint you have to start the engine and bring upto to temperature. I am wondering if this paint is suitable.
Painted my disks with smooth hammerite and my engine/gearbox,all seems well so far.
Animal
you can use it and then put it in the current wifes oven.May kill the taste of food for many a night after tho'.As animal said,I have used smoothrite and seems fine,although nothing garish,just black
Ditto, use smooth hammerite. I've been using it on discs and calipers for years, never had a problem....
used high temp matt black spray paint [VHT] no problem on rear and front discs.no need to heat up. will do that when you next use them. :D
Is it too late to do this if the non-swept area of the discs are rusty?
Kerry
Kerry
My discs front discs I have not even ordered yet. My rear ones are still in the box! So no problem.
Problem is that the next time I use them, i.e. the first time, could be 18 months away!
Kerry
No, but obviously you need to clean the rust off first...
Animal
I would not have though hammerite would be suitable for these temperatures. I guess the engine might reach a few hundred degrees and brakes higher than that I think?
:0  :0  :0  :0
Keep guessing... :bangshead:
I've not convinced that normal road driving gets westfield brakes particularly hot. I'll stand corrected of course, but my simple 'touch it quick to see if it's hot' tests after a drive have never shown the brakes to be more than warm to the touch.
Maybe I'm not driving it hard enough though :)
i normally spray the whole disc ,only lighty on the disc the brake pads soon burn it off but leaves paint on any where  that needs it from getting rusty. :p
if they already rusty just use a rotary wire brush in drill first.
The manifold will certainly see high temps, I guess I could apply a small patch of hammerite to one of the pipes under the bonnet to see how it bears up.
