I've got outer drive flanges off a 4x4 sierra that was originally fitted with ABS. These have the toothed ring on them for the wheel speed sensors.
Does anyone know if these give any problems for fitment to the upright as the ones that Westfield supply don't have them.
As far as know with the abs rings they will not go into the westfield supplied uprights.Could always try and remove them.
If you are building an SDV then I don't think you will have a problem
Steve
If it is a sierra rear set up ie diff as well then it will fit okay. Both previous cars I built had the outer stub axle from a 4x4 with the ABS ring.
