Selling my V1 edis megasquirt... fully working with the latest firmware just needs minor things to finish it off...
Needs heatsinking and 90 degree coms connector adding to replace straight one that was fitted... which I can supply at no extra cost. (coms connector that is)
Has a very loose base map for Zetec 2.0l on there but does need work to make compatable with a zetec or could be used for anything else... Will supply with software and firmware that is installed
Easy to complete... and comes complete with loom to ecu (which is 1ft long to wire in to local electrics, see http://www.megamanual.com/index.html for full details of wiring loom) as well.
Looking for £180 before I let loose on ebay plus postage
*** SOLD ***
