LSD with DRUM BRAKES
I want to change my 3.92 type A diff to LSD. Iv been asking loads of questions and have found out that it cant be done.
i gave BGH Geartech a call today (very helpfull! ) they told me i need to change to a Type B diff (flange type) which will also mean changing my drive shafts.
i then give westfield a call to see if they do the shafts, the tech guy i spoke to said they do!! i got put through to the sales dep and told the shafts will cost £135 for both inc vat, he then said you may need to change the hubs aswell which will be another £130
has anyone done this ?? do i need to change the shafts and hubs or will just changing the shafts do the trick?
anyone?
I guess you are refering to fitting a Ford viscous diff, in which case as you have already found out, isn't going to be straight forward. Might be best to go and get a Quaife unit priced up, might turn out to be the cheapest (and the most hassle free) job.
IIRC Cateringvans use the type A diff, might be a line worth investigating...
What is a type A or type B diff? I have not heard of it. Are we talking sierra diffs here? Or maybe the old 'english' diff used in old escorts?
steve
Both diffs are off a ford sierra. a type A is the early diff with push in drive shafts. Type B is the later (more common) diff with bolt on drive shafts or flange type shafts
BGH said the type A diffs are to small inside to take the viscus pack so would need machining out. So the type A`s can be made into VLSD but at a cost, far more than changing to a Type B and changing the drive shafts
i dont want to swap internals i want to swap diffs
