bootleboy Posted March 24, 2006 Posted March 24, 2006 A long shot this one... I have just returned from working in Holland, where one of my colleagues reckons his old next door neighbour (in the uk) built a 4wd Cossie Westfield? Anybody ever heard of this? Would it be worth the hassle if it was possible?? Aparently he was a regular at trackdays? Quote
Mike H Posted March 24, 2006 Posted March 24, 2006 4x4 Cossie Dax Rush - yes, even a superb V8 4x4 knocking around somewhere. Westfield - no never heard of one, would be interested to see it if it exists. I wouldn't have thought there was enough room in the Westfield chassis. Mike Quote
JeffC Posted March 24, 2006 Posted March 24, 2006 had a blast after a I think was a Dax 4x4 cossie round Croft last year was absolutley sh*te round the bends was like a hyperactive Cow on roller blades but down the straights I couldnt get near it left me Busa for dead , I thought I had a plug lead disconnected guy wouldnt pull over to let me and the Demon barber pass so we passed him under braking into Tower , he followed us out and tried to match our pace round the Jim Clarks and ended up in the field looked like it suffered chronic understeer Quote
ibakes Posted March 24, 2006 Posted March 24, 2006 Z cars built a Tiger with Twin turbo (i think) Hayabusa lumps. front engine powered the front wheels, back engine powered the back wheels and controlled by electronics. 10k plus VAT for the conroller system apparenly. Quote
Marty Posted March 24, 2006 Posted March 24, 2006 Came up against a Dax 4x4 Cossie on a hillclimb event. Such poor lock, could not get around the bends, so no surprise it ended up in the undergrowth. Quote
reaper Posted March 24, 2006 Posted March 24, 2006 Z cars built a Tiger with Twin turbo (i think) Hayabusa lumps. front engine powered the front wheels, back engine powered the back wheels and controlled by electronics. 10k plus VAT for the conroller system apparenly. yeh the zz1100 or somethin similar. not turbo'd but so unreliable that when tiff needell tested it it blew up 4 times. still when it worked it tortured a maclaren f1 Quote
cng1 Posted March 24, 2006 Posted March 24, 2006 The car that tiff tried was the Z100, he certainly did not blow it up 4 times. The twit mis-shifted and overreved the engines, which is what popped them. The 4WD car was the Z100WR which used an upside down sierra diff in the front to drive the front wheels. Engine management was Motec which restricted the power on the front engine in the corners. The cheaper solution would have been to use a smaller engine for the front. All cars were natasp. Quote
tex Posted March 24, 2006 Posted March 24, 2006 4x4 Cossie Dax Rush - yes, even a superb V8 4x4 knocking around somewhere. yes i have seen that 4x4 V8 rush at harrogate last year - what an awesome peice of kit that was - not built for racing but long distance touring - but the finish was outstanding.. i personally think the 4x4 is too over weight - but if you have enuff horses up front and can make it handle.. Quote
reaper Posted March 24, 2006 Posted March 24, 2006 The car that tiff tried was the Z100, he certainly did not blow it up 4 times. The twit mis-shifted and overreved the engines, which is what popped them. my apologies. my brain not working too well today.. twit have to agree with that quote Quote
scooby Posted March 24, 2006 Posted March 24, 2006 I was speaking to a guy at Ears Motorsport 18 months ago who said they got 90% into building a 4x4 cossy westfield but it proved undrivable and they broke the project. Quote
scruffythefirst Posted March 24, 2006 Posted March 24, 2006 Skyline box with active center diff will help, keep all the drive at the back untill you loose traction. will start to get heavy though. Quote
Karl Woolf Posted March 24, 2006 Posted March 24, 2006 The car that tiff tried was the Z100, he certainly did not blow it up 4 times. The twit mis-shifted and overreved the engines, which is what popped them. The 4WD car was the Z100WR which used an upside down sierra diff in the front to drive the front wheels. Engine management was Motec which restricted the power on the front engine in the corners. The cheaper solution would have been to use a smaller engine for the front. All cars were natasp. I thought it was more to do with the gear change both gear levers (each engine had its own gearbox) were tied together with a pin. Tiff shifted and one of the engines didn`t change up a gear, other engine dragged the first engine through its rev limiter to destruction A joint rev limiter for both engines would have saved the day personally didn`t think that was as much Tiff`s fault as poor engineering Quote
cng1 Posted March 25, 2006 Posted March 25, 2006 Karl, the engineering was fine. Even with a twin-limiter you'd still be at the mercy of a downshift when you meant an upshift killing the engines. I suggest that you take a close look at some of the other cars that zcars have done such as tim duncans old twin engined westie you'll find that they are beautifully engineered. Quote
Guest Posted March 25, 2006 Posted March 25, 2006 I am sure there was a pale blue Westfield at Harewood, I guess late 90's, which was 4WD cossie powered. Appeared to be really well engineered and went like the proverbial rodent up a pipe. Quote
Mark Stanton Posted March 25, 2006 Posted March 25, 2006 No 4x4 Westfield There used to be a very fast 4x4 Dax driven by Mr Cowper at many hills and sprints Seems a Westfield isn't quite wide, big enough to allow 4x4 - been quite a few look at at it but nowt If it could have been achieved the factory would probably have done it Quote
