BassMan Posted March 21, 2006 Posted March 21, 2006 I have a bog standard 1600 CVH SEiW with Webber twin 40 DCOE running on a Ford ECU (I guess the standard one). Engine was brand new from Westfield when kit was purchased (1994). ECU has the following markings on it: Ford 91AB-12A297-GA P #A104 2M16 CONQE 3 symbols - triangle, heart, circle. Last time I had the car rolling road tuned the chap said if I tell him the exact model of ECU he can probably download a new map and remap it for me giving more power. Questions: 1) can you remap a standard Ford ECU like this? 2) how much should I expect to pay? 3) how much extra horses would I get? Thought it might be a cheap way of getting a little bit more power (currently got 101bhp at flywheel) while I save up for my Ferriday Engineering head work and new cam Cheers Quote
Blatman Posted March 21, 2006 Posted March 21, 2006 It's not standrad Ford ECU. A standard Ford ECU won't run Webers without remapping, and you can't remap a Ford EECIV ECU... Any chance of a picture? Quote
scruffythefirst Posted March 21, 2006 Posted March 21, 2006 and you can't remap a Ford EECIV ECU... You sure? Quote
markcoopers Posted March 21, 2006 Posted March 21, 2006 Bass man, Keep an eye out for older ECU's that people are selling as they swap from Carbs to Fule injection. THese may well give you all you need and be cheaper than purchasing new Quote
Nick A Posted March 21, 2006 Posted March 21, 2006 you can't remap a Ford EECIV ECU you can plug in a superchip to the diagnostic socket which does alter the mapping and ford could remap the EECIV ECU years ago via the FDS2000 system with an upgrade, not what you mean i know but if they could do it then maybee others can now ? Quote
CrashBangWallop Posted March 21, 2006 Posted March 21, 2006 The guy at Northampton Motorsport said they had recently received the software/ hardware to remap my Ford OFAB ECU but, wasn't up to speed with it, so was unwilling to do mine. Quote
bill shurvinton Posted March 21, 2006 Posted March 21, 2006 http://www.tweecer.com/index.htm But quite a lot tolearn. I started off reprogramming GM ECUs. Really cheap and very powerful, but a LOT of work to sort out. Quote
scruffythefirst Posted March 21, 2006 Posted March 21, 2006 Motorsport developments in blackpool can do it. Quote
BassMan Posted March 22, 2006 Author Posted March 22, 2006 Here's a pic of the ECU: Looks as though it can be remapped then, I'll see what my local rolling road guy has to say. I'm in Kent otherwise a trip to Motorsport Developments in Blackpool would be easiest Thx for advice. Quote
Nick A Posted March 22, 2006 Posted March 22, 2006 thats just an ignition module (edis) i think it just controls the ignition side of things don't know if anything can be done with these Quote
cng1 Posted March 22, 2006 Posted March 22, 2006 Oh I know what that is. There's a vacuum connector on it isn't there although there's no obvious hose in the picture. What you have there is the precursor to the ESC2 ignition modules which were used to control ignition on carbed engines. Later these were replaced by EDIS modules which were controlled from the ECU which did the injection as well. If it is one of those then it dates from the late 80s and is best off binned and replaced with a megajolt as it's completely and utterly untweekable. Quote
Nick A Posted March 22, 2006 Posted March 22, 2006 ESC2 ignition modules that's what i was thinking of ESC 2 = electronic spark control 2 Quote
Blatman Posted March 22, 2006 Posted March 22, 2006 Which confirms at least part of what I said in my opening post... It's not standrad Ford ECU. So, whilst I may be a bit behibnd on the potential mapping possibilities with the EECIV, my suspicion that the item in question wasn't actually an ECU was spot on Quote
BassMan Posted March 22, 2006 Author Posted March 22, 2006 OK, so now I feel stupid So you're saying that I have no ECU controlled system at all, just an old ignition module that can't be tweaked at all. And best advice would be to ditch it and replace with a programmable system of some sort? Am I understanding things now? All parts came from Westfield as a total kit in 1994, including engine and Webbers so I'm surprised the factory supplied this unit if it's quite old. Who knows why! Another rung on the Westfield learning curve ..... Quote
Dave Eastwood (Gadgetman) - Club Chairman Posted March 22, 2006 Posted March 22, 2006 I'm surprised the factory supplied this unit if it's quite old. Who knows why! Sierra diffs aren't made anymore either, but they're broadly suitable and cost effective so Westfield use them. Quote
