adamnreeves Posted March 18, 2006 Share Posted March 18, 2006 Hello All, Yes I fitted this a while ago but I know more now, enough to ask the question at least! The diff I fitted does not accept the westfield stud at the top mount, it is a bolt fitment, common enough situation. I know that M12 x 65mm is the size but I used general automotive strength bolts, i.e. 8.8s. I torqued them to 40nm. Should I have used 10.9 or 12.9s or are 8.8s fine? Quote Link to comment Share on other sites More sharing options...
kipford Posted March 18, 2006 Share Posted March 18, 2006 Adam Grade 8.8 will be perfectly acceptable. You will break the Aluminium casting before the bolt. With the best will in the world tensile strength on the casting will not exceed about 350 MPa. Grade 8.8 bolt is around the 800 MPa mark. Dave Quote Link to comment Share on other sites More sharing options...
adamnreeves Posted March 18, 2006 Author Share Posted March 18, 2006 Adam Grade 8.8 will be perfectly acceptable. You will break the Aluminium casting before the bolt. With the best will in the world tensile strength on the casting will not exceed about 350 MPa. Grade 8.8 bolt is around the 800 MPa mark. Dave Thanks, one less thing I have to worry about, one less job I have to re-do. Quote Link to comment Share on other sites More sharing options...
