Audi A4 Damage - WRITTEN OFF!!
A lot of damage –
The Engine has been moved – so this indicates that the engine mountings on the chassis has been twisted.
Needs a new radiator & cooling fan.
He said that fan blades don’t normally break on side impact damage.
Needs a new power steering rack
New wheel hub / bearing / buckled alloy
Wing
2 doors
Back bumper
“A” Post
Inner “A” Post
"B" Post
Rear quarter
Possible dash board
Glove box
& There’s damage to the bulkhead
Original post here
Probably just as well - you wouldn't want it back after such extensive repairs, would you? ABS ought to have an off switch for snowy days, maybe.???
I've always thought EBD needs an off switch for icy conditions.  You can be driving along on a sheet of ice with the brakes on and if one wheel happens to come upon a patch of grip, the whole car pivots around it.  Bit dangerous if you as me.
Anyway, back on topic, its deifnatley better not to get that back, any chassis damage, and I wouldn't want to drive it again.
Got to be £10k plus. With that much movement in the A pillar the bulkhead was always going to be questionable, I am surprised then engine has moved though. Maybe it has pushed a chassis leg or something as well.
You forgot to include all the T-cut as well :D
It's suprising what seemingly minor damage can cause extensive repairs but there again I guess this is down to modern design methods where energy is absorbed progessively over the structure. All to do with protecting the frail little thing who hold the steering wheel.
Kerry
Answer on Saturday morning................
David
Why not? it will be put back together properly and a far better job than the Audi production line.especially if its a far eastern built/produced shell !
Buzz
David
get them to make the cheque out in my name  :p  :p
got a couple of things in the pipeline may have your name on  ;)  ;)  :p  :p
£8,000 - worst case scenario
8 people got it.......
Ouch, mind you when my A4 was written off last year the repair estimate came to £21000  :(
