Carl Posted March 15, 2006 Posted March 15, 2006 I'm finally getting round to sorting out the garage floor but am unsure what to use. The garage is only 3 years old so the floor is in good nick, but very dusty. Area is about 25m2 (double garage) and I don't want to spend much more than £100. Anyone have any useful advice, tips, or knowledge of a hole in a tile warehouse Quote
Ted Posted March 15, 2006 Posted March 15, 2006 No knowledge of tile warehouse's, sorry. Had 2 garage's now, one I just painted with floor paint from B&Q and the other has some old carpet from a house clearance (keeps the tyres warm and more comfortable than hard floor) TED Quote
stu.graham Posted March 15, 2006 Posted March 15, 2006 I used garage floor paint on the concrete floor, keeps the dust down, hard wearing and easy to clean. Screwfix or B & Q. HTH Stu Quote
JeffC Posted March 15, 2006 Posted March 15, 2006 industrial black office carpet , should be in your budget mines been down 3 years and good as new still Quote
Darren B Posted March 15, 2006 Posted March 15, 2006 Painted 2 garage floors using B&Q stuff. Had same problem with dust before but now very good...especially for cleaning up those little spills of fluids. Quote
Gavin Posted March 15, 2006 Posted March 15, 2006 While on the subject, I have a newish garage and whoever built it just before I brought the place used block paving for the floor.I have never seen this before and it is rubbish for keeping clean etc because all of the ruts between the blocks.Anyone any ideas what I could do with it again on a budget and without ripping it all up ? Quote
studbuckle Posted March 15, 2006 Posted March 15, 2006 You could put some self levelling floor sealant on it, might take a bit to fill up the ridges but should work. I've just sealed the 10 year old concrete floor in my garage ready for painting. Mix of PVA and water, couple of coats and it's ready for painting. At the last house I didn't do this first and the tyres lifted the paint very quickly Quote
hilux Posted March 15, 2006 Posted March 15, 2006 At the last house I didn't do this first and the tyres lifted the paint very quickly You need to use a surface hardner, paint lifts when its only bonded to friable surface. the floor is in good nick, but very dusty. Ditto above Quote
Blatman Posted March 15, 2006 Posted March 15, 2006 At the last house I didn't do this first and the tyres lifted the paint very quickly You need to use a surface hardner On the unpainted floor, or the paint? Quote
MAT1800 Posted March 15, 2006 Posted March 15, 2006 I have a newish garage and whoever built it just before I brought the place used block paving for the floor Anyone any ideas what I could do with it again on a budget and without ripping it all up ? How about some tile grout between the blocks? Quote
Martin Keene Posted March 15, 2006 Posted March 15, 2006 I've just sealed the 10 year old concrete floor in my garage ready for painting. Mix of PVA and water, couple of coats and it's ready for painting. Make sure you leave it for long enough to dry out. Ideally up to a week. We only left ours for a little over 24 hours and it was no where near long enough and the paint hasn't stuck in a lot of places. If I was to do it again I'd use a two part epoxy based paint. Quote
steve_m Posted March 15, 2006 Posted March 15, 2006 If I was doing my garage again I'd use a thin layer of the self leveling concrete stuff, then some cheap vinyl tiles. Kneeling on a little concrete spike is not to be recommended I also sealed the walls and painted them white, makes a huge difference. Quote
Carl Posted March 15, 2006 Author Posted March 15, 2006 Thanks for the info. Still not sure about paint, will it chip off under axles stands? Tiles seem to expensive, so I might try some rubber matting Quote
ChrisG Posted March 15, 2006 Posted March 15, 2006 Ive heard mixed reports about the cheaper paints such as those from B&Q, they often peel off a bit when hot sticky tyres are rolled over them or chip when things are dropped on them. I used something called Jotun Jotafloor (google it), its a proper industrial 2 part epoxy floor paint that only a handful of places sell and its brilliant stuff, you could take the angle grinder to it and I doubt it would shift! For a double garage it may be slightly over your budget as it cost me about £100 for enough to do my single garage (2 cans), but that was very rough old concrete that absorbed a lot and needed 2 coats, so you may only need 2-3 cans to do a smoother less absorbent concrete floor. Edited to add: Actually, my garage is about 20ft long so slightly bigger than your average single garage, maybe 15m² Quote
hilux Posted March 15, 2006 Posted March 15, 2006 On the unpainted floor No, on new concrete. Abrade the surface laitance (loose particles with a stiff broom - a wire brush if you`re really keen) hoover or brush thoroughly and brush on the hardner. This ensures all particles are bonded and gives a good key to the paint. PVA sort of does the same but `sticks` the surface particles together and will not stand the twisting of tyres or lots of trolley jacks etc FWIW I am a career builder/project manager and have done this on many floors (factories and warehouses etc) I HIGHLY recommend WATCO whose products will maintain and repair your floors brilliantly. Cheapest isnt best but I have used their products for years. They last for years too so possibly worth it in the long run. You can colour match your floor to your car HTH Quote
